Hey all,
I have a small question regarding scripts in Phoebus.
For our detector we use an Image widget to display the hit map of our
Pixel sensor(s).
Sometimes it happens that some Pixel of our detector are very noisy and
we want to mask them.
As an easy way of generating the pixel mask configuration, we thought
about using local PVs for the cursor feature of the image widget and an
action button which executes a (python) script that takes the X and Y
coordinates of the cursor and adds this pixel to our mask config.
Unfortunately we are unable to get this to work, as it seems we can only
add 1 PV to the script executed by an Action Button.
Is there any way to use more then 1 PV with scripts that should be
executed via an Action Button?
Also in another setup we have a small script that checks some
configuration. When this script is executed a stack trace is visible in
the console showing the error "python not found".
Other scripts work fine. Any idea what could be the cause of such an error?
Thanks for the help in advance.
Cheers,
Florian
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone: (+49)234 / 32-23563
Fax: (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
- Re: [EXTERNAL] Scripts in Phoebus Kasemir, Kay via Tech-talk
Re: MRF EvtClk object not found Michael Davidsaver via Tech-talk
<2023>
2025
2026
RE: MRF EvtClk object not found Daykin, Evan via Tech-talk
<2023>
2025
2026
