1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: A question on usage of the IP parameter in Asyn
To: Amber <[email protected]>, tech-talk <[email protected]>
Date: Thu, 17 Aug 2023 15:53:38 +0000
Hi Kevin,
        drvAsynIPPortConfigure("IPPort","192.168.1.7:18881",0,0,1)
        xxxDriverConfigure("Port1", "IPPort", NULL)
    Then I put the  "int Deviceopen=OpenSession(handle, IPPortName/portName)"  in the  xxxDriver::xxxDriver( ) function,
    with location behind  "status=pasynOctetSyncIO->connect(IPPortName, 0, &pasynUserIPPort_, NULL);", the connection failed again.
The string “IPPort” which is passed to your driver as IPPortName is not the string 192.168.1.7:18881.  It is the string “IPPort”, and is the name of a new asynIPPort driver you created with the first line above.  In your case you are actually not using that asynIPPort driver at all.  You can simply your startup script and driver like this:
< envPaths
cd "${TOP}"
dbLoadDatabase("./dbd/Driver.dbd")
xxxDriver_registerRecordDeviceDriver(pdbbase)
epicsEnvSet("IPPort","192.168.1.7:18881")
xxxDriverConfigure("Port1", "$(IPPort)", NULL)
dbLoadRecords("./db/xxxDriver.db","P=QS,R=6300:,PORT=Port1,ADDR=0,TIMEOUT=1")
dbLoadRecords("./db/asynRecord.db","P=QS,R=6300:,PORT=Port1,ADDR=0,OMAX=80,IMAX=80")
iocInit()
Remove these lines from your driver, you don’t need them:
                    if (status) {
                           printf("%s:%s:pasynOctetSyncIO->connect failure, status=%d\n",driverName, functionName, status);
                   return;
In the Configure function you can now use this line:
               int Deviceopen=OpenSession(handle,IPPortName);
From: Tech-talk <[email protected]> On Behalf Of Amber via Tech-talk
Sent: Thursday, August 17, 2023 3:49 AM
To: tech-talk <[email protected]>
Subject: A question on usage of the IP parameter in Asyn
Hello everyone,
      I write an IOC with asyn based on the template in <epics>/Support/asyn/testConnect.
     When I connect the device with a function in libxxxcontrol.so, I do not know how to use Parameter
     1.  The st.cmd file is like this:
      #!../../bin/linux-x86_64/xxxDriver
       < envPaths
        cd "${TOP}"
        # Turn on asynTraceFlow and asynTraceError for global trace, i.e. no connected asynUser.
        iocInit()
     2.  In the xxxDriver.cpp :
        xxxDriver::xxxDriver(const char *portName,const char *IPPortName, const char *outputString)
           : asynPortDriver(portName,
                            1, /* maxAddr */
                            asynInt32Mask | asynFloat64Mask | asynFloat64ArrayMask | asynEnumMask | asynDrvUserMask, /* Interface mask */
                            asynInt32Mask | asynFloat64Mask | asynFloat64ArrayMask | asynEnumMask,  /* Interrupt mask */
                            0, /* asynFlags.  This driver does not block and it is not multi-device, so flag is 0 */
                            1, /* Autoconnect */
                            0, /* Default priority */
                            0) /* Default stack size*/
                    asynStatus status;
                    int channelnum;
                    double position0;
                    const char *functionName = "xxxDriver";
                    if (status) {
                   return;
      int xxxDriverConfigure(const char *portName,const char *IPPortName, const char *outputString)
                new xxxDriver(portName,IPPortName,outputString);
                handle=Init();
                int Deviceopen=OpenSession(handle,"192.168.1.7:18881");
                //int Deviceopen=OpenSession(handle,IPPortName); //portName? IPPortName?  Device connect failed
                if (Deviceopen==1) {
                        printf("Device is found.\r\n");
                        printf("Channels number is:%d\r\n", Num);
                        printf("pisition1 is %s\r\n", buffer);
               return(asynSuccess);
 3.  My Question is:
     in the xxxDriverConfigure( ),the IP address "192.168.1.7:18881"  is used directly in this sentence:  int Deviceopen=OpenSession(handle,"192.168.1.7:18881");
     If  I change the "192.168.1.7:18881" to be "IPPortName" or "portName" :
     int Deviceopen=OpenSession(handle, IPPortName),  or  int Deviceopen=OpenSession(handle, portName);
     the device can't be connected.  The IPPortName or portName can not be substituted by "192.168.1.7:18881", though we have these two sentences in the st.cmd file:
   How can I use a parameter defined in the st.cmd instead of a detailed IP like "xxx.xxx.xxx.xxx"?
   Why can't I use the IPPortName or portName directly in the .cpp file? What's the correct usage of the two parameters?
   That's all.  Thank you very much for any of your reply.
Best reguards,
Kevin
A question on usage of the IP parameter in Asyn =?gb18030?b?QW1iZXI=?= via Tech-talk
Prev: Re: Dante Mark Rivers via Tech-talk
Next: Re: Dante Siddons, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: A question on usage of the IP parameter in Asyn =?gb18030?b?QW1iZXI=?= via Tech-talk
Next: Dante D Peter Siddons via Tech-talk
