1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Can we set 'NELM' tobe a variable in waveform or subArray?
From: =?gb18030?b?S2V2aW4=?= via Tech-talk <[email protected]>
To: "=?gb18030?b?dGVjaC10YWxr?=" <[email protected]>
Date: Sun, 20 Aug 2023 11:41:11 +0800
Hello everyone,
I used waveform to read  8 channels data, the waveform record is:
record(waveform, "$(P)Countxxyy")
  field(DTYP, "stream")
  field(INP, "@ct0801f.proto Counters_in  $(PORT)")
  field(NELM, "8")
  field(FTVL, "LONG")
  field(SCAN, "$(SCAN)")
The user hope that the NELM is a variable,  so I used $(P)N  to controller the readout numbers:
record(waveform, "$(P)Counters")
  field(NELM, "$(P)N")
  field(FTVL, "LONG")
 When $(P)N changed, the $(P)Countxxyy keep an initial value. I think that the NELM can not be modified:
Then I found the modify property about NELM in subArray is ¡®yes¡¯,
So I changed the record like this:
  field(NELM, "8")
  field(FTVL, "LONG")
record(subArray,"$(P)Countersxy") {
  field (DESC, "Read counterx~countery")
  field (INP, "$(P)Counters")
  field (MALM, "8")
  field (NELM, "$(P)N")
  field (INDX, "0")
  field (SCAN, "$(SCAN)")
When the $(P)N changed tobe 4, $(P)Countersxy.NELM doesn't change. It is still the inital value 1, and $(P)Countersxy read only 1 channel data.
Can we set the NELM tobe a variable?
How could we read changing channels from the above 8 channel datas?
I am confused and ask for help. Thank you so much.
With my best reguards,
Kevin
Re: Can we set 'NELM' tobe a variable in waveform or subArray? Mark Rivers via Tech-talk
Prev: Job Opportunity at HZDR Meyer, Markus via Tech-talk
Next: Re: Can we set 'NELM' tobe a variable in waveform or subArray? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
