1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: PV Access issue when moving between subnets
From: Jim Larsson via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 23 Aug 2023 13:48:41 +0000
Hello Tech Talk,
We have encountered an issue with pv access when a host running an ioc switch network. The host is a mini-pc and obtains a new ip from dhcp. After the switch, the pvs from the ioc are not accessible with pv access, e.g., pvget. However, the pvs can still be obtained with channel access (both before and after switching network).
Some findings after switching network:
 => Pv access works if the ioc is restarted.
 => Pv access works if executing 'stopPVAServer' and 'startPVAServer' in the ioc shell.
 => Pvget locally doesn't work.
 => pvget to an ioc on a different host on the network works.
 => Channel access continuous to work after switching network.
Versions:
pvAccess server v7.1.6
epics-base v7.0.7
# ioc shell
> pvasr
EPICS_PVAS_INTF_ADDR_LIST = 0.0.0.0:5075
EPICS_PVAS_BEACON_ADDR_LIST =
EPICS_PVAS_AUTO_BEACON_ADDR_LIST = YES
EPICS_PVAS_BEACON_PERIOD = 15
EPICS_PVAS_BROADCAST_PORT = 5076
EPICS_PVAS_SERVER_PORT = 5075
EPICS_PVAS_PROVIDER_NAMES = QSRV local
Has anyone else experienced something similar? Preferably we would like to find a solution so that it is not required to restart the ioc for pv access to work (same as channel access).
Kind regards,
Jim
Re: PV Access issue when moving between subnets Michael Davidsaver via Tech-talk
Prev: Re: Epics 7 on Mac M2 (arm64) Heinz Junkes via Tech-talk
Next: USBCTR08 ch0 scaler counts missing Keith Surrena via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: mrfioc2 driver support Shen, Guobao via Tech-talk
Next: Re: PV Access issue when moving between subnets Michael Davidsaver via Tech-talk
ANJ, 25 Aug 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
