1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: areaDetector driver for BitFlow frame grabbers
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 25 Aug 2023 19:55:57 +0000
Folks,
I am about to embark on writing a new areaDetector driver that will support CoaXPress and CameraLink frame grabbers from BitFlow (https://www.bitflow.com/).
I am writing to see if anyone else has already developed an areaDetector driver for BitFlow frame grabbers?
My initial target is a Mikrotron EoSens 2.0 CXP2 CoaXPress camera.  It is 1920x1080 pixels with a maximum frame rate of 2247 frames/s.  It uses 4 lanes each running at 12.5 Gbps.
These are my current plans for the implementation:
  • Use the BitFlow SDK API for streaming, rather than the generic GenTL API which they also support.  The reason is that they claim the BitFlow API has much better performance.
  • Use the BitFlow BFGTLUtil API for GenICam feature access, rather than the native GenICam API.  The reason is that it is much simpler and easier to use.
  • Implement the driver on both Linux and Windows.  Their SDK APIs are similar but not identical on Linux and Windows.
Prev: Re: PV Access issue when moving between subnets Michael Davidsaver via Tech-talk
Next: Re: Phoebus configuration and PV connection Najm Us Saqib via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: RE: Phoebus configuration and PV connection CAOUEN Loic via Tech-talk
Next: sscan build error Vishnu Patel via Tech-talk
ANJ, 29 Aug 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
