1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: Phoebus configuration and PV connection
From: CAOUEN Loic via Tech-talk <[email protected]>
To: Najm Us Saqib <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 28 Aug 2023 08:27:36 +0000
Hi Xiaomin,
Phoebus connects directly to the kafka server to check the alarms.
Kafka may listen to local host ip only and does not allow the connection from phoebus.
You can force external ip by changing the server.properties in your kafka config folder:
listeners=PLAINTEXT://10.101.8.1:9092
Check also if your firewall is open on port 9092.
Regards
De : Tech-talk <[email protected]> De la part de Najm Us Saqib via Tech-talk
Envoyé : samedi 26 août 2023 10:34
À :
刘晓敏 <[email protected]>
Cc : [email protected]
Objet : Re: Phoebus configuration and PV connection
Hi Xiaomin,
Your question sparked a memory from a few years ago. I am not an expert but your query looks similar. Give a try to the solution suggested by Kunal in the screenshot below, it worked for me.
Best,
Najm
On Wed, Aug 23, 2023 at 8:27 PM 刘晓敏 via Tech-talk <[email protected]> wrote:
I had a problem with phobus, when phoebus and alarm-server are on the same server, it runs without problems. But when I put phoebus-product on the client side and alarm-server on the server side, run ./phoebus.sh on the client side, and run ./alarm-server.sh on the server side, the phoebus connection fails, showing ‘No Alarm Server Connection’.
Kafka running on the service end is no problem. The configuration file settings .ini is as follows:
org.phoebus.pv.ca/addr_list=10.101.1.1
org.phoebus.applications.alarm/server=10.101.8.1:9092
org.phoebus.applications.alarm/config_alarm=Accelerator
org.phoebus.applications.alarm/config_alarm=Accelerator,Demo
I don't think there's anything wrong with that.
What is the reason for this error?
xiaomin
Phoebus configuration and PV connection 刘晓敏 via Tech-talk
Re: Phoebus configuration and PV connection Najm Us Saqib via Tech-talk
Prev: Re: Phoebus configuration and PV connection Najm Us Saqib via Tech-talk
Next: RE: USBCTR08 ch0 scaler counts missing Keith Surrena via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: areaDetector driver for BitFlow frame grabbers Mark Rivers via Tech-talk
