1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Build system question
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Sun, 10 Sep 2023 16:57:57 +0000
I have a questions about the build system on Windows when directory names contain space characters.
I have a vendor library in “C:\BitFlow SDK 6.5”.  It contains Include/ and Lib64/ directories.  I want to build my application using the files in those directories.
My application Makefile contains lines like:
USR_INCLUDES += -I$(BITFLOW_SDK_INCLUDE)
PROD_LIBS_WIN32 += BFGTLUtil
USR_LDFLAGS_WIN32 += /LIBPATH:$(BITFLOW_SDK_LIB)
I created CONFIG_SITE.windows-x64-static.Common with these lines:
BITFLOW_SDK_INCLUDE = “C:/BitFlow SDK 6.5/Include”
BITFLOW_SDK_LIB     = “C:/BitFlow SDK 6.5/Lib64”
That does not work because of the embedded spaces in the folder name.  I also tried this:
BITFLOW_SDK_INCLUDE = “C:/BitFlow\ SDK\ 6.5/Include”
BITFLOW_SDK_LIB     = “C:/BitFlow\ SDK\ 6.5/Lib64”
Is there a way to make it work when the folder name contains space characters?
I ended up renaming the vendor directory to replace spaces with underscores.  I also had to remove the quotation marks in the CONFIG_SITE file.
BITFLOW_SDK_INCLUDE = C:/BitFlow_SDK_6.5/Include
BITFLOW_SDK_LIB     = C:/BitFlow_SDK_6.5/Lib64
Re: Build system question Pete Jemian via Tech-talk
Prev: Phoebus Databrowser Florian Feldbauer via Tech-talk
Next: Re: Build system question Pete Jemian via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
ANJ, 10 Sep 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
