Scratch that non-working suggestion.
Here's the one I've used in the past, that uses `~NUMBER` to stay within the 8.3 filename rule of older Windows.
https://superuser.com/a/743627
Actual: "E:\Program Files\Java\Eclipse\eclipse.exe"
shorter: "E:\Progra~1\Java\Eclipse\eclipse.exe"
The `1` resolves ambiguities if there are more than one entry that begin with the characters before the `~`. In this case, use the first possibility.
Pete
On 9/10/2023 11:59 AM, Pete Jemian wrote:
Can you replace a single blank space with %20?
On 9/10/2023 11:57 AM, Mark Rivers via Tech-talk wrote:
I have a questions about the build system on Windows when directory names contain space characters.
I have a vendor library in “C:\BitFlow SDK 6.5”. It contains Include/ and Lib64/ directories. I want to build my application using the files in those directories.
My application Makefile contains lines like:
USR_INCLUDES += -I$(BITFLOW_SDK_INCLUDE)
PROD_LIBS_WIN32 += BFGTLUtil
USR_LDFLAGS_WIN32 += /LIBPATH:$(BITFLOW_SDK_LIB)
I created CONFIG_SITE.windows-x64-static.Common with these lines:
BITFLOW_SDK_INCLUDE = “C:/BitFlow SDK 6.5/Include”
BITFLOW_SDK_LIB = “C:/BitFlow SDK 6.5/Lib64”
That does not work because of the embedded spaces in the folder name. I also tried this:
BITFLOW_SDK_INCLUDE = “C:/BitFlow\ SDK\ 6.5/Include”
BITFLOW_SDK_LIB = “C:/BitFlow\ SDK\ 6.5/Lib64”
Is there a way to make it work when the folder name contains space characters?
I ended up renaming the vendor directory to replace spaces with underscores. I also had to remove the quotation marks in the CONFIG_SITE file.
BITFLOW_SDK_INCLUDE = C:/BitFlow_SDK_6.5/Include
BITFLOW_SDK_LIB = C:/BitFlow_SDK_6.5/Lib64
Pete R. Jemian, Ph.D. <[email protected]>
Beam line Controls and Data Acquisition (BC, aka BCDA)
Advanced Photon Source, Argonne National Laboratory
Argonne, IL 60439 630 - 252 - 3189
Education is the one thing for which people
are willing to pay yet not receive.
- Re: Build system question Pete Jemian via Tech-talk
- Build system question Mark Rivers via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
