Dear All,
We have some device controlled via raw serial communication. Streamdevice reads a weird 1 byte null data (as far as we are understanding). We expect that 15 byte data are read back normally when 7 byte command is sent. send cmd: 0x16 0x16 0x80 0x00 0x00 0x80 0x1A read-back: 0x16 0x16 0x80 0x00 0x08 (two 4 byte float) checksum 0x1A However, unexpected 1 byte null(\x00) character is read. Sometimes, this null character is read together with our read-back data, which causes an input error as shown in iocshell console message. Do you have any idea about this? Thanks, Hyung JIn Kim ================================================================= iocshell console message: 2023/09/15 10:57:29.891 192.168.85.191:4001 write 7 16 16 80 00 00 80 1a 2023/09/15 10:57:29.903 192.168.85.191:4001 read 15 16 16 80 00 08 00 80 22 43 00 00 c0 40 6d 1a 2023/09/15 10:57:29.912 192.168.85.191:4001 read 1 00 2023/09/15 10:57:31.891 192.168.85.191:4001 write 7 16 16 80 00 00 80 1a 2023/09/15 10:57:31.895 192.168.85.191:4001 read 1 00 2023/09/15 10:57:31.903 192.168.85.191:4001 read 15 16 16 80 00 08 00 80 22 43 00 00 c0 40 6d 1a 2023/09/15 10:57:31.912 192.168.85.191:4001 read 1 00 2023/09/15 10:57:32.913154 PHWRB41 SCL32-RF03:SSPA-B41:#getInfo: Input "<00><16><16><80><00><08><00><80>"C<00><00><c0>@m<1a><00>" 2023/09/15 10:57:32.913470 PHWRB41 SCL32-RF03:SSPA-B41:#getInfo: mismatch after 0 bytes "" 2023/09/15 10:57:32.913730 PHWRB41 SCL32-RF03:SSPA-B41:#getInfo: got "<00><16><16><80><00><08><00><80>"C..." where "<16>" was expected 2023/09/15 10:57:33.891 192.168.85.191:4001 write 7 16 16 80 00 00 80 1a 2023/09/15 10:57:33.903 192.168.85.191:4001 read 15 16 16 80 00 08 00 80 22 43 00 00 c0 40 6d 1a 2023/09/15 10:57:33.912 192.168.85.191:4001 read 1 00 2023/09/15 10:57:35.891 192.168.85.191:4001 write 7 16 16 80 00 00 80 1a 2023/09/15 10:57:35.903 192.168.85.191:4001 read 15 16 16 80 00 08 00 80 22 43 00 00 c0 40 6d 1a 2023/09/15 10:57:35.912 192.168.85.191:4001 read 1 00 2023/09/15 10:57:37.891 192.168.85.191:4001 write 7 16 16 80 00 00 80 1a 2023/09/15 10:57:37.903 192.168.85.191:4001 read 15 16 16 80 00 08 00 80 22 43 00 00 c0 40 6d 1a 2023/09/15 10:57:37.911 192.168.85.191:4001 read 1 00 2023/09/15 10:57:39.891 192.168.85.191:4001 write 7 16 16 80 00 00 80 1a 2023/09/15 10:57:39.895 192.168.85.191:4001 read 1 00 2023/09/15 10:57:39.903 192.168.85.191:4001 read 15 16 16 80 00 08 00 80 22 43 00 00 c0 40 6d 1a 2023/09/15 10:57:40.904437 PHWRB41 SCL32-RF03:SSPA-B41:#getInfo: Input "<00><16><16><80><00><08><00><80>"C<00><00><c0>@m<1a>" 2023/09/15 10:57:40.904748 PHWRB41 SCL32-RF03:SSPA-B41:#getInfo: mismatch after 0 bytes "" 2023/09/15 10:57:40.905012 PHWRB41 SCL32-RF03:SSPA-B41:#getInfo: got "<00><16><16><80><00><08><00><80>"C..." where "<16>" was expected 2023/09/15 10:57:41.891 192.168.85.191:4001 write 7 16 16 80 00 00 80 1a 2023/09/15 10:57:41.903 192.168.85.191:4001 read 15 16 16 80 00 08 00 80 22 43 00 00 c0 40 6d 1a 2023/09/15 10:57:41.911 192.168.85.191:4001 read 1 00 ... =========================================================================== For reference, here is a part of our protocol: Terminator = "\x1A"; ExtraInput = Ignore; query_head = "\x16\x16\x80"; query_tail = "\x00%2<sum8>"; get_dev_info { Separator = ""; out $query_head "\x00" $query_tail; in $query_head "\x00\x08" "%#4R" "%2<sum8>"; } Our database is as follows: record(aai, "${SYS}${SUBSYS}${DEV}${SUBDEV}#getInfo") { field (DESC, "Get Freq and Firmware") field (SCAN, "2 second") field (DTYP, "stream") field (INP, "@sspaRFPT.proto get_dev_info(${SYS}${SUBSYS}${DEV}${SUBDEV}) $(PORT)") field (NELM, "2") field (FTVL, "FLOAT") } =========================================================================== Our st.cmd looks like : ... drvAsynIPPortConfigure("PHWRB41", "192.168.85.191:4001", 0,0,0) asynSetOption("PQWR001", 0, "baud", "115200") #asynSetOption("PQWR001", 0, "bits", "8") #asynSetOption("PQWR001", 0, "stop", "1") #asynSetOption("PQWR001", 0, "parity", "none") ... asynSetTraceMask ("PHWRB41", 0, 9) asynSetTraceIOMask("PHWRB41", 0, 4) dbLoadTemplate("${TOP}/db/sspaRFPT.substitutions", "") ...
ANJ, 18 Oct 2023 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
