1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Streamdevice reads weird 1 byte null data
From: Zimoch Dirk via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 15 Sep 2023 07:30:37 +0000
Hello Hyung Jin,
I will try to reproduce this behavior.
BTW: For binary protocols (using formats like %r or %R) using
Terminator/InTerminator is problematic because the binary data may contain the
terminator byte. Often, binary protocols have fixed message sizes. I suggest to
use MaxInput in that case.
Dirk
On Fri, 2023-09-15 at 15:27 +0900, Hyung Jin Kim via Tech-talk wrote:
> Dear All,
> We have some device controlled via raw serial communication. Streamdevice reads a weird 1 byte null data (as far as we are understanding).
> We expect that 15 byte data are read back normally when 7 byte command is sent.
> send cmd: 0x16 0x16 0x80 0x00 0x00 0x80 0x1A
> read-back: 0x16 0x16 0x80 0x00 0x08 (two 4 byte float) checksum 0x1A
> However, unexpected 1 byte  null(\x00) character is read. Sometimes, this null character is read together with our read-back data, which causes an input error as shown in iocshell console message.
> Do you have any idea about this?
> Thanks,
> Hyung JIn Kim
> iocshell console message:
> 2023/09/15 10:57:29.891 192.168.85.191:4001 write 7
> 16 16 80 00 00 80 1a
> 2023/09/15 10:57:29.903 192.168.85.191:4001 read 15
> 16 16 80 00 08 00 80 22 43 00 00 c0 40 6d 1a
> 2023/09/15 10:57:29.912 192.168.85.191:4001 read 1
> 00
> 2023/09/15 10:57:31.891 192.168.85.191:4001 write 7
> 2023/09/15 10:57:31.895 192.168.85.191:4001 read 1
> 00
> 2023/09/15 10:57:31.903 192.168.85.191:4001 read 15
> 2023/09/15 10:57:31.912 192.168.85.191:4001 read 1
> 00
> 2023/09/15 10:57:32.913154 PHWRB41 SCL32-RF03:SSPA-B41:#getInfo: Input "<00><16><16><80><00><08><00><80>"C<00><00><c0>@m<1a><00>"
> 2023/09/15 10:57:32.913470 PHWRB41 SCL32-RF03:SSPA-B41:#getInfo: mismatch after 0 bytes ""
> 2023/09/15 10:57:32.913730 PHWRB41 SCL32-RF03:SSPA-B41:#getInfo: got "<00><16><16><80><00><08><00><80>"C..." where "<16>" was expected
> 2023/09/15 10:57:33.891 192.168.85.191:4001 write 7
> 2023/09/15 10:57:33.903 192.168.85.191:4001 read 15
> 2023/09/15 10:57:33.912 192.168.85.191:4001 read 1
> 00
> 2023/09/15 10:57:35.891 192.168.85.191:4001 write 7
> 2023/09/15 10:57:35.903 192.168.85.191:4001 read 15
> 2023/09/15 10:57:35.912 192.168.85.191:4001 read 1
> 00
> 2023/09/15 10:57:37.891 192.168.85.191:4001 write 7
> 2023/09/15 10:57:37.903 192.168.85.191:4001 read 15
> 2023/09/15 10:57:37.911 192.168.85.191:4001 read 1
> 00
> 2023/09/15 10:57:39.891 192.168.85.191:4001 write 7
> 2023/09/15 10:57:39.895 192.168.85.191:4001 read 1
> 00
> 2023/09/15 10:57:39.903 192.168.85.191:4001 read 15
> 2023/09/15 10:57:40.904437 PHWRB41 SCL32-RF03:SSPA-B41:#getInfo: Input "<00><16><16><80><00><08><00><80>"C<00><00><c0>@m<1a>"
> 2023/09/15 10:57:40.904748 PHWRB41 SCL32-RF03:SSPA-B41:#getInfo: mismatch after 0 bytes ""
> 2023/09/15 10:57:40.905012 PHWRB41 SCL32-RF03:SSPA-B41:#getInfo: got "<00><16><16><80><00><08><00><80>"C..." where "<16>" was expected
> 2023/09/15 10:57:41.891 192.168.85.191:4001 write 7
> 2023/09/15 10:57:41.903 192.168.85.191:4001 read 15
> 2023/09/15 10:57:41.911 192.168.85.191:4001 read 1
> 00
> For reference, here is a part of our protocol:
> Terminator  = "\x1A";
> ExtraInput    = Ignore;
> query_head    = "\x16\x16\x80";
> query_tail    = "\x00%2<sum8>";
> get_dev_info
>     Separator = "";
>     out  $query_head "\x00" $query_tail;
>     in  $query_head "\x00\x08"
>         "%#4R"
>         "%2<sum8>";
> Our database is as follows:
> record(aai, "${SYS}${SUBSYS}${DEV}${SUBDEV}#getInfo") {
>   field (DESC, "Get Freq and Firmware")
>   field (SCAN, "2 second")
>   field (DTYP, "stream")
>   field (INP,  "@sspaRFPT.proto get_dev_info(${SYS}${SUBSYS}${DEV}${SUBDEV}) $(PORT)")
>   field (NELM, "2")
>   field (FTVL, "FLOAT")
> Our st.cmd looks like :
> drvAsynIPPortConfigure("PHWRB41", "192.168.85.191:4001", 0,0,0)
> asynSetOption("PQWR001", 0, "baud", "115200")
> #asynSetOption("PQWR001", 0, "bits", "8")
> #asynSetOption("PQWR001", 0, "stop", "1")
> #asynSetOption("PQWR001", 0, "parity", "none")
> asynSetTraceMask  ("PHWRB41", 0, 9)
> asynSetTraceIOMask("PHWRB41", 0, 4)
> dbLoadTemplate("${TOP}/db/sspaRFPT.substitutions", "")
Re: Streamdevice reads weird 1 byte null data Ralph Lange via Tech-talk
Streamdevice reads weird 1 byte null data Hyung Jin Kim via Tech-talk
Prev: Re: PVA connection problem Ralph Lange via Tech-talk
Next: Re: PVA connection problem Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Streamdevice reads weird 1 byte null data Hyung Jin Kim via Tech-talk
Next: Re: Streamdevice reads weird 1 byte null data Ralph Lange via Tech-talk
