1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: PVA connection problem
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Jure Varlec <[email protected]>
Cc: [email protected]
Date: Fri, 15 Sep 2023 14:10:30 +0200
On 9/15/23 11:20, Jure Varlec via Tech-talk wrote:
On 9/15/23 09:24, Ralph Lange via Tech-talk wrote:
Sorry for asking the obvious:
Have you tried adding the PVA ports 5075/5076 in the same way as the CA ports 5064/5065?
Cheers,
~Ralph
But note that, depending on the firewall's connection tracking, just adding these ports may not be sufficient to talk to IOCs because of an issue in pvAccessCPP. Ask me how I know ...
https://github.com/epics-base/pvAccessCPP/issues/159
Thank you for giving me an opportunity to mention that PVXS address both issues :)
Concerning #159 , a PVXS server search replies will come from the search port (5076/udp by default),
so a stateful firewall can more easily associate search request with reply.
Also, PVXS servers use EPICS_PVAS_SERVER_PORT to choose a fixed TCP port other than 5075,
which can help in situations with a firewall and more than one IOC.
https://mdavidsaver.github.io/pvxs/
RE: PVA connection problem [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
PVA connection problem Ignacio Arriagada via Tech-talk
Re: PVA connection problem Ralph Lange via Tech-talk
Re: PVA connection problem Jure Varlec via Tech-talk
Prev: Re: PVA connection problem Jure Varlec via Tech-talk
Next: Re: [EXTERNAL] PVA connection problem Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: RE: PVA connection problem [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
