1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: PVA connection problem [SEC=UNOFFICIAL]
From: "STARRITT, Andrew via Tech-talk" <[email protected]>
To: 'EPICS Tech-Talk' <[email protected]>, Michael Davidsaver <[email protected]>, Jure Varlec <[email protected]>
Date: Tue, 3 Oct 2023 04:07:56 +0000
Hi all,
What was the final solution here?
I tried on one of our Control Room OPI hosts.
With the client side firewall off, everything worked as expected.
With client side firewall on, I had no access, even with using pvxs.
The host running the IOC is hosting only one IOC; and its firewall is on.
The client host is running  CentOS Stream 8, and the firewall rules,
pvget and pvxget info is show below.
[host]# firewall-cmd  --list-all
public (active)
  target: default
  icmp-block-inversion: no
  interfaces: enp0s31f6
  sources:
  services: cockpit dhcpv6-client rdp ssh vnc-server zabbix-agent
  ports: 5064/udp 5064/tcp 5065/udp 5065/tcp 5075/udp 5075/tcp 5076/udp 5076/tcp
  protocols:
  forward: no
  masquerade: no
  forward-ports:
  source-ports: 5064/udp 5064/tcp 5065/udp 5065/tcp 5075/udp 5075/tcp 5076/udp 5076/tcp
  icmp-blocks:
  rich rules:
[host]$ pvget -V
pvAccess 7.1.6
pvData 8.0.5
Base 7.0.7
[host]$ pvxget -V
PVXS 1.2.3 (2023-10-03T03:18+1100)
EPICS 7.0.7
libevent 2.1.8-stable
Regards
Andrew
PS A throw away question, maybe worthy of its own thread. Why is there no pvaRepeater?
UNOFFICIAL
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Michael Davidsaver via Tech-talk
Sent: Friday, 15 September 2023 10:11 PM
To: Jure Varlec <[email protected]>
Cc: [email protected]
Subject: Re: PVA connection problem
CAUTION, EXTERNAL EMAIL: This message has come from outside of ANSTO. Do not take action, click links or open attachments unless you trust the source of this message and know the content is safe. Report spam and phishing using the Report Message button or if unsure, forward this message to [email protected] as an attachment.
On 9/15/23 11:20, Jure Varlec via Tech-talk wrote:
> On 9/15/23 09:24, Ralph Lange via Tech-talk wrote:
>> Sorry for asking the obvious:
>> Have you tried adding the PVA ports 5075/5076 in the same way as the CA ports 5064/5065?
>> Cheers,
>> ~Ralph
> But note that, depending on the firewall's connection tracking, just adding these ports may not be sufficient to talk to IOCs because of an issue in pvAccessCPP. Ask me how I know ...
> https://gith/
> ub.com%2Fepics-base%2FpvAccessCPP%2Fissues%2F159&data=05%7C01%7Candrew
> s%40ansto.gov.au%7C6b7f50e0c54a4d58b23708dbb5e4d08c%7C4cbf9a84567a44d0
> 9db11dbfbf8393f0%7C0%7C0%7C638303766597515999%7CUnknown%7CTWFpbGZsb3d8
> eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3
> 000%7C%7C%7C&sdata=IXAsxtcFRhq72oi1UJaNzUhymPBgRrMV5LQWKxpPQX8%3D&rese
> rved=0
Thank you for giving me an opportunity to mention that PVXS address both issues :)
Concerning #159 , a PVXS server search replies will come from the search port (5076/udp by default), so a stateful firewall can more easily associate search request with reply.
Also, PVXS servers use EPICS_PVAS_SERVER_PORT to choose a fixed TCP port other than 5075, which can help in situations with a firewall and more than one IOC.
https://mdavidsaver.github.io/pvxs/
Re: PVA connection problem [SEC=UNOFFICIAL] Jure Varlec via Tech-talk
PVA connection problem Ignacio Arriagada via Tech-talk
Re: PVA connection problem Ralph Lange via Tech-talk
Re: PVA connection problem Jure Varlec via Tech-talk
Re: PVA connection problem Michael Davidsaver via Tech-talk
Prev: Re: Multiple layers of DB templates? Gregory, Ray via Tech-talk
Next: RE: Use sscan with transform record coordinate motion Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: PVA connection problem Michael Davidsaver via Tech-talk
Next: Re: PVA connection problem [SEC=UNOFFICIAL] Jure Varlec via Tech-talk
