1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: PVA connection problem [SEC=UNOFFICIAL]
From: Jure Varlec via Tech-talk <[email protected]>
To: "STARRITT, Andrew" <[email protected]>, 'EPICS Tech-Talk' <[email protected]>, Michael Davidsaver <[email protected]>
Date: Tue, 3 Oct 2023 09:57:08 +0200
On 10/3/23 06:07, STARRITT, Andrew wrote:
Caution: This email originated from outside of Cosylab.
Hi all,
What was the final solution here?
I tried on one of our Control Room OPI hosts.
With the client side firewall off, everything worked as expected.
With client side firewall on, I had no access, even with using pvxs.
Hi Andrew,
As Michael summarized, the PVXS *server* responds in a different (and more conformant way) than the old server based on pvAcessCPP. Meaning, using PVXS on the client won't help. The solution is rebuilding your IOC with QSRV2 [1], which is based on PVXS [2], while noting that this stuff is still experimental and that defaults could change [3]. For us, the issue arises in a staging environment for a project where we can't use QSRV2, so we weren't able to test this, but given the nature of the problem, I'm pretty sure it should work with the usual one-way firewalls. If you can give QSRV2 a test drive, it would be great, and many of us would be grateful; this stuff should get more testing.
[1] https://mdavidsaver.github.io/pvxs/ioc.html#qsrv-2
[2] https://mdavidsaver.github.io/pvxs/building.html#includepvxs
[3] https://github.com/mdavidsaver/pvxs/pull/58
Best,
Jure
PVA connection problem Ignacio Arriagada via Tech-talk
Re: PVA connection problem Ralph Lange via Tech-talk
Re: PVA connection problem Jure Varlec via Tech-talk
Re: PVA connection problem Michael Davidsaver via Tech-talk
RE: PVA connection problem [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
Prev: RE: Use sscan with transform record coordinate motion Abdalla Ahmad via Tech-talk
Next: Re: Use sscan with transform record coordinate motion Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: RE: PVA connection problem [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
Next: Re: PVA connection problem Michael Davidsaver via Tech-talk
