1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: static libraries
To: "Siddons, David" <[email protected]>
Date: Mon, 18 Sep 2023 18:52:00 +0000
Hi Pete,
That fact that it says it is looking for a static library is misleading. It really just means it cannot find the library at all.  You need to change the Makefile to:
ssd1306_i2c_DIR    = /usr/local/lib/
That is telling where to find that specific library.
You could probably also eliminate that line and use:
display_SYS_LIBS   += ssd1306_i2c
assuming /usr/local/lib is in the default system library search path.
Sent from my iPhone
On Sep 18, 2023, at 2:32 PM, Siddons, David via Tech-talk <[email protected]> wrote:
Hi Tech-talk,
I need to use a library in an EPICS app, set up using MakeBaseApp. It wants to have a static version of the library, which the library package doesn't supply. Why does it need the static library? I'm not trying to build a static program. Here's the Makefile fragment which builds it:
PROD_HOST += display
display_SRCS   += display.c
display_LIBS   += ezca
display_DIR    = /usr/local/lib/
display_LIBS   += ssd1306_i2c
display_LIBS   += $(EPICS_BASE_HOST_LIBS)
and it gives:
make[1]: *** No rule to make target '../../lib/linux-arm/libssd1306_i2c.a', need
ed by 'display'.  Stop.
I'm building it natively on a Zynq Debian 10 system. The shared libraries are in /usr/local/lib:
/usr/local/lib/libssd1306_i2c.la  /usr/local/lib/libssd1306_i2c.so.0
/usr/local/lib/libssd1306_i2c.so  /usr/local/lib/libssd1306_i2c.so.0.0.3
Pete.
Re: static libraries Siddons, David via Tech-talk
Fw: Dante-1-1 Siddons, David via Tech-talk
Prev: static libraries Siddons, David via Tech-talk
Next: Re: static libraries Siddons, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
