1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Help to ADCore 3.12.1 with RIXSCam IOC and PluginXIP
From: Érico Nogueira Rolim via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, Nicolas Guilhermo Silva Moliterno <[email protected]>, "[email protected]" <[email protected]>
Cc: SWC <[email protected]>
Date: Thu, 21 Sep 2023 20:13:31 +0000
Hi Mark,
I was helping Nicolas out with debugging this.
The `deleteCallbackThreads` error message was printed during IOC initialization, because processing the NumThreads or QueueSize PVs (which have PINI=YES) causes the NDPluginDriver::deleteCallbackThreads() function to be called, and it failed for some unknown reason...
We were attempting to clean up all errors from the iocsh output before testing the plugin; so I don't think we have information on whether the plugin works when the deleteCallbackThreads function has errored out.
Cheers,
Érico
On 21/09/2023 16:56, Mark Rivers wrote:
Hi Nicolas,
The error you were getting was only when exiting the IOC, correct?  That is a minor problem, and I don’t think your fix is the correct solution.
Ø  I needed to avoid the NDPluginDriverQueueSize and NDPluginDriverNumThreads functions, because XIP has this message:
Ø  Specify BlockCallbacks to true, which is how it should stay.
BlockCallbacks is independent of NDPluginDriverQueueSize and NDPluginDriverNumThreads.  There is no need to “avoid” them.  You can change plugins from blocking to non-blocking at runtime in the OPI, and the current setting is normally restored with autosave, so the value in the startup script typically does not matter.
From: Nicolas Guilhermo Silva Moliterno <[email protected]>
Sent: Wednesday, September 20, 2023 1:45 PM
To: Mark Rivers <[email protected]>; [email protected]
Subject: RE: Help to ADCore 3.12.1 with RIXSCam IOC and PluginXIP
Hi Mark,
  • I am not sure what you are trying to do.  Do you want to run ADCore 2.2.0 or 3.12.1?
I already have full IOC compiled for ADCore 2.2.0.
I'm trying to update to the latest version of ADCore=3.12.1.
·         If you
·         are building with R3.12.1 then why are you trying to avoid calling the
·         base class for NDPluginDriverQueueSize and NDPluginDriverNumThreads?
Because when trying to run IOC to the latest version, I get these errors in the IOC prompt:
NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
NDPluginDriver::writeInt32 ERROR, status=3, function=57, value=1, connectedToArrayPort_=1
NDPluginXIP:writeInt32: error, status=3 function=57
IPE:RIXSCam1:XIP1:NumThreads devAsynInt32::processCallbackOutput process error.
After avoiding calling the functions, the errors did not occur. But the problem of resetting the PVs arose
IPE:RIXSCam1:XIP1:ArraySize2_RBV = 0
IPE:RIXSCam1:XIP1:ArraySize1_RBV = 0
In the IOC cmd file using ADCore=2.2.0, the plugins look like this:
# Create a netCDF file saving plugin.
NDFileNetCDFConfigure("FileNetCDF1", $(QSIZE), 0, "$(PORT)", 0)
dbLoadRecords("NDFileNetCDF.template","P=$(PREFIX),R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
# Load XIP plugin.  Specify BlockCallbacks to true, which is how it should stay.
NDPluginXIPConfigure("XIP1", $(QSIZE), 1, "$(PORT)", 0, -1, -1)
dbLoadRecords("NDPluginXIP.template", "P=$(PREFIX),R=XIP1:,  PORT=XIP1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
In the IOC cmd file using ADCore=3.12.1, the plugins look like this:
dbLoadRecords("$(ADPLUGINXIP)/db/NDPluginXIP.template", "P=$(PREFIX),R=XIP1:,PORT=XIP1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
dbLoadRecords("$(ADPLUGINXIP)/db/XIPPVDefinitions.template", "P=$(PREFIX),R=XIP1:,PORT=XIP1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
I didn't try to reset the argument like other plugins.
Thanks.
[email protected]
Grupo SWC-Software de Controle / Control Software Group
Laboratório Nacional de Luz Síncrotron - LNLS Centro Nacional de Pesquisa em Energia e Materiais - CNPEM
De: Mark Rivers <[email protected]>
Enviado: quarta-feira, 20 de setembro de 2023 14:45
Para: Nicolas Guilhermo Silva Moliterno <[email protected]>; [email protected] <[email protected]>
Assunto: RE: Help to ADCore 3.12.1 with RIXSCam IOC and PluginXIP
Hi Nicolas,
I am not sure what you are trying to do.  Do you want to run ADCore 2.2.0 or 3.12.1?  I strong suggest you run the more recent version.
  • I think it's something related to the version of ADCore=2.2.0, it doesn't handle NDPluginDriverQueueSize and NDPluginDriverNumThreads.
R2-2 did have NDPluginDriverQueueSize but not NDPluginDriverNumThreads.
I got around this problem with the code:
asynStatus NDPluginXIP::writeInt32(asynUser *pasynUser, epicsInt32 value)
/* If this parameter belongs to a base class, call its method */
if (function < FIRST_NDPluginXIP_PARAM && function != NDPluginDriverQueueSize && function != NDPluginDriverNumThreads)
status = NDPluginDriver::writeInt32(pasynUser, value);
I don’t understand what you are doing.  If you are building with ADCore R2-2 then NDPluginDriverNumThreads will not be defined and you will get a compiler error.  If you are building with R3.12.1 then why are you trying to avoid calling the base class for NDPluginDriverQueueSize and NDPluginDriverNumThreads?  The base class does need to be called for those parameters.
Sent: Wednesday, September 20, 2023 12:20 PM
To: [email protected]
Cc: Mark Rivers <[email protected]>; SWC <[email protected]>
Subject: Help to ADCore 3.12.1 with RIXSCam IOC and PluginXIP
Hi everyone, I'm compiling a RIXSCam detector.
I compiled EPICS BASE = 7.0.7
SYNAPPS = 6.2 with AreaDetector -> ADCore, ADSupport.
I was successful in compiling the entire system, detector and epics modules.
But after compiling and changing the version of ADCore, the XIP plugin has been showing strange behavior.
In the new version of ADCore = 3.12.1, it handles these functions.
int function = pasynUser->reason;
asynStatus status = setIntegerParam(function, value);
for (auto histogramParam : _histogramParams)
if (histogramParam->HasParameterIndex(function))
_histogramParamsChanged = true;
break;
/* Do callbacks so higher layers see any changes */
callParamCallbacks();
ReportWriteStatus(pasynUser, status, "writeInt32");
return status;
But after that, IOC zeroed out the Array Size. And by definition, this is the PluginXIP call.
set_requestfile_path("$(ADPLUGINXIP)", "Db")
I needed to make the change in deleteCallbackThreads and createCallbackThreads, because when we raised the IOC, the shell showed: errors involving these two functions:
2023/07/11 12:00:50.994 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2023/07/11 12:00:51.001 NDPluginDriver::writeInt32 ERROR, status=3, function=57, value=1, connectedToArrayPort_=1
2023/07/11 12:00:51.011 NDPluginXIP:writeInt32: error, status=3 function=57
2023/07/11 12:00:51.019 IPE:RIXSCam1:XIP1:NumThreads devAsynInt32::processCallbackOutput process error
I think it might be something related to the PVs
·         IPE:RIXSCam1:XIP1:QueueFree
·         IPE:RIXSCam1:XIP1:QueueSize
Because in the image with ADCore 2.2.0, the PVs IPE:RIXSCam1:XIP1:QueueSize and IPE:RIXSCam1:XIP1:QueueFree have the values ​​1 and 1 respectively.
While with ADCore 3.12.1 they have the values ​​1 and 0 respectively.
Thanks.
[email protected]
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
RE: Help to ADCore 3.12.1 with RIXSCam IOC and PluginXIP Mark Rivers via Tech-talk
Help to ADCore 3.12.1 with RIXSCam IOC and PluginXIP Nicolas Guilhermo Silva Moliterno via Tech-talk
RE: Help to ADCore 3.12.1 with RIXSCam IOC and PluginXIP Nicolas Guilhermo Silva Moliterno via Tech-talk
Prev: RE: Help to ADCore 3.12.1 with RIXSCam IOC and PluginXIP Mark Rivers via Tech-talk
Next: RE: Help to ADCore 3.12.1 with RIXSCam IOC and PluginXIP Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
