1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Strange error in EPICS client program
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Jörn Dreyer <[email protected]>
Cc: [email protected]
Date: Fri, 22 Sep 2023 08:41:02 -0700
On 9/22/23 01:19, Jörn Dreyer via Tech-talk wrote:
Hello,
I recently run into a problem with a client code that throws strange errors at
me during runtime:
CA client library tcp recieve thread terminating due to C++ exception
"epicsMutex::invalidMutex()"
"invalidMutex" indicates a coding error.  (NULL dereference, memory corruption,
use-after-free, ...)
Hopefully you can reproduce this error quickly, I would suggest running in GDB and
setting a breakpoint on the exception class ctor 'epicsMutex::invalidMutex::invalidMutex()'.
Then look for signs of corruption.
epicsMutex pthread_mutex_lock failed: error epicsMutexOSDLock
epicsThread: Unexpected C++ exception "epicsMutex::invalidMutex()" with type
"N10epicsMutex12invalidMutexE" in thread "CAC-TCP-send" at XXX
terminate called after throwing an instance of 'epicsMutex::invalidMutex()'
    what():  epicsMutex::invalidMutex()
After that my program crashes. Can anybody shed some light on that. It was
running all good until two days ago when this error started to pop up when a
connection to a PV is made.
Jörn Dreyer
Strange error in EPICS client program Jörn Dreyer via Tech-talk
Prev: Re: Monitor timeouts with asyn/StreamDevice, and issues in DRTO with UDP Zimoch Dirk via Tech-talk
Next: Synapps CAMAC debian Rute Mendes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Strange error in EPICS client program Jörn Dreyer via Tech-talk
Next: "I/O Intr" record not processing boj via Tech-talk
