1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: USB permissions
From: Jörn Dreyer via Tech-talk <[email protected]>
Date: Tue, 26 Sep 2023 05:46:31 +0200
Hi Mark,
on some systems, especially those with systemd, there is another directory
where udev looks for rules files. Did you check in
/usr/lib/udev/rules.d
for a file that might set the permissions for those devices?
Regards
Jörn
Am Montag, 25. September 2023, 23:52:10 CEST schrieb Mark Rivers via Tech-
talk:
> Folks,
> I am seeing something I don't understand about USB device permissions on
> Linux.  I have two Centos 9 systems, each connected to 3 USB devices from
> Measurement Computing.
> On the system called 13ide I needed to install a udev rules file in order to
> give these USB devices world write permission.
> This is part of the rules file:
> (base) [epics@13ide ~]$ more /etc/udev/rules.d/50-uldaq.rules
> SUBSYSTEM=="usb", ATTR{idVendor}=="09db", ATTR{idProduct}=="0076",
> GROUP="adm", MODE="0666" SUBSYSTEM=="usb", ATTR{idVendor}=="09db",
> ATTR{idProduct}=="007f", GROUP="adm", MODE="0666" SUBSYSTEM=="usb",
> ATTR{idVendor}=="09db", ATTR{idProduct}=="0085", GROUP="adm", MODE="0666"
> SUBSYSTEM=="usb", ATTR{idVendor}=="09db", ATTR{idProduct}=="0086",
> ATTR{idProduct}=="008a", GROUP="adm", MODE="0666"
> lsusb shows that the devices are on bus 002, devices 005, 007, and 008.
> (base) [epics@13ide ~]$ lsusb
> Bus 002 Device 009: ID 0557:2259 ATEN International Co., Ltd LCD Console
> V1.3.124 Bus 002 Device 006: ID 0557:2259 ATEN International Co., Ltd LCD
> Console V1.3.124 Bus 002 Device 004: ID 0557:8021 ATEN International Co.,
> Ltd Hub
> Bus 002 Device 008: ID 09db:013e Measurement Computing Corp. USB-1808X
> Bus 002 Device 007: ID 09db:009d Measurement Computing Corp. USB-3104
> Bus 002 Device 005: ID 09db:0127 Measurement Computing Corp. USB-CTR08
> This shows that those devices have permission 666 and are owned by the "adm"
> group.
> (base) [epics@13ide ~]$ ls -l /dev/bus/usb/002
> total 0
> crw-rw-r-- 1 root root 189, 128 Sep 19 11:45 001
> crw-rw-r-- 1 root root 189, 129 Sep 19 11:45 002
> crw-rw-r-- 1 root root 189, 130 Sep 19 11:45 003
> crw-rw-r-- 1 root root 189, 131 Sep 19 11:45 004
> crw-rw-rw- 1 root adm  189, 132 Sep 19 11:45 005
> crw-rw-r-- 1 root root 189, 133 Sep 19 11:45 006
> crw-rw-rw- 1 root adm  189, 134 Sep 19 11:45 007
> crw-rw-rw- 1 root adm  189, 135 Sep 19 11:45 008
> crw-rw-r-- 1 root root 189, 136 Sep 19 11:45 009
> This makes sense to me because permission 666 and group "adm" are in the
> 50-uldaq.rules file.
> However, I have another system which does not have a udev rules file in that
> location.
> [epics@13idc ~]$ ls -l /etc/udev/rules.d/
> total 0
> On that system the devices are on bus 001, devices 004, 005, and 006.
> [epics@13idc udev]$ lsusb
> Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
> Bus 001 Device 010: ID 1604:10c0 Tascam Dell Integrated Hub
> Bus 001 Device 009: ID 413c:a102 Dell Computer Corp. iDRAC Virtual NIC
> Bus 001 Device 007: ID 1604:10c0 Tascam Dell Integrated Hub
> Bus 001 Device 003: ID 1604:10c0 Tascam Dell Integrated Hub
> Bus 001 Device 006: ID 09db:013e Measurement Computing Corp. USB-1808X
> Bus 001 Device 005: ID 09db:009d Measurement Computing Corp. USB-3104
> Bus 001 Device 004: ID 09db:0127 Measurement Computing Corp. USB-CTR08
> Bus 001 Device 002: ID 0409:005a NEC Corp. HighSpeed Hub
> Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
> The following shows that these devices also have permissions 666 and are in
> the "adm" group.
> [epics@13idc udev]$ ls -l /dev/bus/usb/001
> total 0
> crw-rw-r-- 1 root root 189, 0 Sep 19 12:09 001
> crw-rw-r-- 1 root root 189, 1 Sep 19 12:09 002
> crw-rw-r-- 1 root root 189, 2 Sep 19 12:09 003
> crw-rw-rw- 1 root adm  189, 3 Sep 19 12:09 004
> crw-rw-rw- 1 root adm  189, 4 Sep 19 12:09 005
> crw-rw-rw- 1 root adm  189, 5 Sep 19 12:09 006
> crw-rw-r-- 1 root root 189, 6 Sep 19 12:09 007
> crw-rw-r-- 1 root root 189, 8 Sep 19 12:09 009
> crw-rw-r-- 1 root root 189, 9 Sep 19 12:09 010
> I don't understand this, since there is no rules file.  How did it know to
> assign these permissions and group?  Is there another mechanism by which
> USB devices get permissions assigned?
> Thanks,
> Mark
Re: USB permissions Mark Rivers via Tech-talk
RE: USB permissions Mark Rivers via Tech-talk
Prev: Re: USB permissions Mark Rivers via Tech-talk
Next: Re: USB permissions Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
