1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: USB permissions
To: Jörn Dreyer <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 26 Sep 2023 16:35:17 +0000
Hi Jörn,
Thanks, indeed all of the udev rules files on my Centos 9 systems are in /usr/lib/udev/rules.d, not in /etc/udev/rules.d.  The file that changes the permissions for the Measurement Computing devices is 50-uldaq.rules.  It is present in /usr/lib/udev/rules.d on all of the systems that I use with Measurement Computing devices.  It gets installed when one builds their uldaq library from source.
-----Original Message-----
Sent: Monday, September 25, 2023 10:47 PM
To: [email protected]
Cc: Mark Rivers <[email protected]>
Subject: Re: USB permissions
Hi Mark,
on some systems, especially those with systemd, there is another directory where udev looks for rules files. Did you check in
for a file that might set the permissions for those devices?
Regards
Jörn
Am Montag, 25. September 2023, 23:52:10 CEST schrieb Mark Rivers via Tech-
talk:
> Folks,
> I am seeing something I don't understand about USB device permissions
> on Linux.  I have two Centos 9 systems, each connected to 3 USB
> devices from Measurement Computing.
> On the system called 13ide I needed to install a udev rules file in
> order to give these USB devices world write permission.
> This is part of the rules file:
> (base) [epics@13ide ~]$ more /etc/udev/rules.d/50-uldaq.rules
> SUBSYSTEM=="usb", ATTR{idVendor}=="09db", ATTR{idProduct}=="0076",
> GROUP="adm", MODE="0666" SUBSYSTEM=="usb", ATTR{idVendor}=="09db",
> ATTR{idProduct}=="007f", GROUP="adm", MODE="0666" SUBSYSTEM=="usb",
> ATTR{idVendor}=="09db", ATTR{idProduct}=="0085", GROUP="adm", MODE="0666"
> SUBSYSTEM=="usb", ATTR{idVendor}=="09db", ATTR{idProduct}=="0086",
> ATTR{idProduct}=="008a", GROUP="adm", MODE="0666"
> lsusb shows that the devices are on bus 002, devices 005, 007, and 008.
> (base) [epics@13ide ~]$ lsusb
> Bus 002 Device 009: ID 0557:2259 ATEN International Co., Ltd LCD
> Console
> V1.3.124 Bus 002 Device 006: ID 0557:2259 ATEN International Co., Ltd
> LCD Console V1.3.124 Bus 002 Device 004: ID 0557:8021 ATEN
> International Co., Ltd Hub Bus 002 Device 008: ID 09db:013e
> Measurement Computing Corp. USB-1808X Bus 002 Device 007: ID 09db:009d
> Measurement Computing Corp. USB-3104 Bus 002 Device 005: ID 09db:0127
> Measurement Computing Corp. USB-CTR08
> This shows that those devices have permission 666 and are owned by the "adm"
> group.
> (base) [epics@13ide ~]$ ls -l /dev/bus/usb/002 total 0
> crw-rw-r-- 1 root root 189, 128 Sep 19 11:45 001
> crw-rw-r-- 1 root root 189, 129 Sep 19 11:45 002
> crw-rw-r-- 1 root root 189, 130 Sep 19 11:45 003
> crw-rw-r-- 1 root root 189, 131 Sep 19 11:45 004
> crw-rw-rw- 1 root adm  189, 132 Sep 19 11:45 005
> crw-rw-r-- 1 root root 189, 133 Sep 19 11:45 006
> crw-rw-rw- 1 root adm  189, 134 Sep 19 11:45 007
> crw-rw-rw- 1 root adm  189, 135 Sep 19 11:45 008
> crw-rw-r-- 1 root root 189, 136 Sep 19 11:45 009
> This makes sense to me because permission 666 and group "adm" are in
> the 50-uldaq.rules file.
> However, I have another system which does not have a udev rules file
> in that location.
> [epics@13idc ~]$ ls -l /etc/udev/rules.d/ total 0
> On that system the devices are on bus 001, devices 004, 005, and 006.
> [epics@13idc udev]$ lsusb
> Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001
> Device 010: ID 1604:10c0 Tascam Dell Integrated Hub Bus 001 Device
> 009: ID 413c:a102 Dell Computer Corp. iDRAC Virtual NIC Bus 001 Device
> 007: ID 1604:10c0 Tascam Dell Integrated Hub Bus 001 Device 003: ID
> 1604:10c0 Tascam Dell Integrated Hub Bus 001 Device 006: ID 09db:013e
> Measurement Computing Corp. USB-1808X Bus 001 Device 005: ID 09db:009d
> Measurement Computing Corp. USB-3104 Bus 001 Device 004: ID 09db:0127
> Measurement Computing Corp. USB-CTR08 Bus 001 Device 002: ID 0409:005a
> NEC Corp. HighSpeed Hub Bus 001 Device 001: ID 1d6b:0002 Linux
> Foundation 2.0 root hub
> The following shows that these devices also have permissions 666 and
> are in the "adm" group.
> [epics@13idc udev]$ ls -l /dev/bus/usb/001 total 0
> crw-rw-r-- 1 root root 189, 0 Sep 19 12:09 001
> crw-rw-r-- 1 root root 189, 1 Sep 19 12:09 002
> crw-rw-r-- 1 root root 189, 2 Sep 19 12:09 003
> crw-rw-rw- 1 root adm  189, 3 Sep 19 12:09 004
> crw-rw-rw- 1 root adm  189, 4 Sep 19 12:09 005
> crw-rw-rw- 1 root adm  189, 5 Sep 19 12:09 006
> crw-rw-r-- 1 root root 189, 6 Sep 19 12:09 007
> crw-rw-r-- 1 root root 189, 8 Sep 19 12:09 009
> crw-rw-r-- 1 root root 189, 9 Sep 19 12:09 010
> I don't understand this, since there is no rules file.  How did it
> know to assign these permissions and group?  Is there another
> mechanism by which USB devices get permissions assigned?
> Thanks,
> Mark
Re: USB permissions Guruswamy, Tejas via Tech-talk
USB permissions Mark Rivers via Tech-talk
Re: USB permissions Jörn Dreyer via Tech-talk
Prev: Re: USB permissions Mark Rivers via Tech-talk
Next: undefined reference to symbol 'pvar_dset_asynInt32ArrayWfIn' Peter Pitfield via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: USB permissions Guruswamy, Tejas via Tech-talk
