If getting a traceback via a debugger is an option, then you can also attempt to set a watchpoint for the pNDArrayPool member of the NDArray object, in order to find out when it gets set to 0.
Cheers,
Érico
On 28/09/2023 10:18, Mark Rivers via Tech-talk wrote:
Hi Heinz,
Some questions:
- Have any images been collected before this error?
- What plugins are running?
- What happens if you disable all plugins before starting acquisition?
- Can you get a traceback when NDArray::release is called and NDArray.pNDArrayPool is 0?
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta
ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying
to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
- Re: Running area detector simulator IOC on OS X aarch64 (M2) , segmentation fault Heinz Junkes via Tech-talk
- Running area detector simulator IOC on OS X aarch64 (M2) , segmentation fault Heinz Junkes via Tech-talk
- RE: Running area detector simulator IOC on OS X aarch64 (M2) , segmentation fault Mark Rivers via Tech-talk
- Re: Running area detector simulator IOC on OS X aarch64 (M2) , segmentation fault Mark Rivers via Tech-talk
Re: update to Phytron motor support Kevin Peterson via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
