Lutz,
The pull request has been merged.
Kevin
On 9/26/23 20:33, Lutz Rossa wrote:
Hello Kevin,
I would kindly ask to merge the pull request in case you did not get
negative feedback.
I've got no feed back via tech-talk nor email after starting this
conversation.
Best regards,
Lutz
Am 24.07.23 um 16:20 schrieb Kevin Peterson:
Lutz,
Thanks for the pull request.
I would strongly encourage users of motorPhytron to test this. I
don't have any phytron controllers so if the code compiles and no one
has any feedback, I'll merge the pull request. The changes to the
code look good to me.
Kevin
On 7/21/23 01:06, Lutz Rossa via Tech-talk wrote:
Hello,
we made some improvements to the support module for Phytron motor
controllers (phyMOTION, www.phytron.eu).
Please have a look to this pull request and give feedback:
<https://github.com/epics-motor/motorPhytron/pull/7>
Best regards,
Lutz
- update to Phytron motor support Lutz Rossa via Tech-talk
- Re: update to Phytron motor support Kevin Peterson via Tech-talk
- Re: update to Phytron motor support Lutz Rossa via Tech-talk
Re: Running area detector simulator IOC on OS X aarch64 (M2) , segmentation fault Érico Nogueira Rolim via Tech-talk
Phoebus EDM autoconvert issue with a button widget Lucas Russo via Tech-talk
<2023>
2025
2026
NTEnum Gabriel Fedel via Tech-talk
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
