1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: [EXTERNAL] Phoebus EDM autoconvert issue with a button widget
From: Lucas Russo via Tech-talk <[email protected]>
To: "Kasemir, Kay" <[email protected]>
Date: Fri, 29 Sep 2023 08:52:13 -0700
Hi Kay,
Interesting. Thanks for the fast response.
Lucas
On Fri, Sep 29, 2023, 06:05 Kasemir, Kay <[email protected]> wrote:
Hi:
In your example EDM files, the “activeButtonClass” objects contain “controlBitPos” values to select a bit.
The converter looks for “controlBitsPos”, https://github.com/ControlSystemStudio/phoebus/blob/d1183073c5929fbc454ef47dfcbdbce28cc7cd11/app/display/convert-edm/src/main/java/org/csstudio/display/converter/edm/widgets/Convert_activeButtonClass.java#L30
Looks like a typo that went unnoticed because nobody has tried to convert EDM files with bit-buttons before.
Check https://github.com/ControlSystemStudio/phoebus/issues/2832 for updates
From: Tech-talk <[email protected]> on behalf of Lucas Russo via Tech-talk <[email protected]>
Date: Thursday, September 28, 2023 at 7:16 PM
To: EPICS Tech Talk <[email protected]>
Subject: [EXTERNAL] Phoebus EDM autoconvert issue with a button widget
Hi all,
I'm trying to autoconvert an EDM file (.edl) to Phoebus (.bob) using the
Phoebus autoconvert feature.
It's mostly working, but the autoconverter doesn't seem to understand the
EDM Button Widget "Bit" field, in which it lets you set a single bit in a PV.
When I autoconvert this file, the generated .bob doesn't contain that information
and sets all buttons to the default bit "0".
I created a simple github repository with a minimal screen to reproduce the issue,
I'm using Phoebus 4.7.3-SNAPSHOT, build "master 2023-07-25 14:51"
Has anybody encountered a similar issue?
Lucas
Phoebus EDM autoconvert issue with a button widget Lucas Russo via Tech-talk
Re: [EXTERNAL] Phoebus EDM autoconvert issue with a button widget Kasemir, Kay via Tech-talk
Prev: Re: Sequencer handling of waveforms with dynamic size Johnson, Andrew N. via Tech-talk
Next: CAMAC module port to Linux Rute Mendes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: [EXTERNAL] Phoebus EDM autoconvert issue with a button widget Kasemir, Kay via Tech-talk
Next: Sequencer handling of waveforms with dynamic size Jure Varlec via Tech-talk
