1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Investigating performance issues with Xflash detector IOC on Windows 10
To: Rami Khrais <[email protected]>
Date: Mon, 2 Oct 2023 13:16:55 +0000
Hi Rami,
Are you using a standard serial connection, or the Bruker QM100 interface card?
Sent from my iPhone
On Oct 2, 2023, at 8:05 AM, Rami Khrais via Tech-talk <[email protected]> wrote:
Hello,
I am working on a detector IOC for Xflash, but I have encountered some issues. When I load periodic scan records, such as ReadTemperature, from the RontecXFlash.db file using the epics setup on Windows 10, the GUI freezes, and I cannot read or collect data from the detector. Additionally, when I stop the previous PVs and try to collect data, it takes longer than expected, and the dead time is not calculated. This behavior only occurs when using the epics setup, and the original Xflash software works correctly.
What is the main cause of this problem and how can we solve it?
Kind regards,
Rami Khrais.
Control software engineer.
SESAME (Synchrotron-light for Experimental Science and Applications in the Middle East).
Investigating performance issues with Xflash detector IOC on Windows 10 Rami Khrais via Tech-talk
Prev: Investigating performance issues with Xflash detector IOC on Windows 10 Rami Khrais via Tech-talk
Next: SIMM and related fields for motor records Gregory, Ray via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: Investigating performance issues with Xflash detector IOC on Windows 10 Rami Khrais via Tech-talk
