1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Investigating performance issues with Xflash detector IOC on Windows 10
From: Rami Khrais via Tech-talk <[email protected]>
Date: Thu, 28 Dec 2023 09:55:27 +0000
Please accept my apologize, I just realized that my last response regarding the MCA (RontecXFlash) issue did not reach you.
I want to update you that we have identified the problem which was related to the communication parameters, specifically the baud rate. After contacting to the company, they provided us with the proper configuration and parameters. We have made these changes, and the communication issue has been successfully resolved.
Thank you for your support and best regards.
Sent: Tuesday, October 3, 2023 4:36 PM
To: Rami Khrais <[email protected]>
The first thing to do is to use asynTrace to look at the communication with the device.  In you startup script after creating the serial port add these lines
asynSetTraceIOMask(PORT, -1, ESCAPE)
asynSetTraceMask(PORT, -1, ERROR|DRIVER)
Then you will see all of the communication with the device.  You can see if some command is timing out or taking a very long time to respond.
You can get even more information by changing the above command to:
asynSetTraceMask(PORT, -1, ERROR|DEVICE|FLOW|DRIVER)
Sent: Tuesday, October 3, 2023 1:13 AM
Hi Mark,
I'm using a standard serial connection.
Sent: Monday, October 2, 2023 4:16 PM
Cc: [email protected] <[email protected]>
Hi Rami,
Are you using a standard serial connection, or the Bruker QM100 interface card?
Sent from my iPhone
On Oct 2, 2023, at 8:05 AM, Rami Khrais via Tech-talk <[email protected]> wrote:
Hello,
I am working on a detector IOC for Xflash, but I have encountered some issues. When I load periodic scan records, such as ReadTemperature, from the RontecXFlash.db file using the epics setup on Windows 10, the GUI freezes, and I cannot read or collect data from the detector. Additionally, when I stop the previous PVs and try to collect data, it takes longer than expected, and the dead time is not calculated. This behavior only occurs when using the epics setup, and the original Xflash software works correctly.
What is the main cause of this problem and how can we solve it?
Kind regards,
Rami Khrais.
Control software engineer.
SESAME (Synchrotron-light for Experimental Science and Applications in the Middle East).
Investigating performance issues with Xflash detector IOC on Windows 10 Rami Khrais via Tech-talk
Re: Investigating performance issues with Xflash detector IOC on Windows 10 Mark Rivers via Tech-talk
Prev: Question about cross compile of epics 문석호 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Investigating performance issues with Xflash detector IOC on Windows 10 Mark Rivers via Tech-talk
Next: SIMM and related fields for motor records Gregory, Ray via Tech-talk
