Hi Maren,
I think my question is why not? That's one usual place where you install binaries/libaries in a linux system that is not a package (.deb, .rpm). To my knowledge the recommendation is /usr/local for "local" packages.
Lucas
The part I don't understand is why you want to install it in system space in the first place. We never have. Install it somewhere you have write access to and add that to your $PATH?
Maren Purves Head of Instrument and Telescope Software East Asian Observatory/JCMT
On 10/9/23 16:15, Lucas Russo via
Tech-talk wrote:
Caution: This email
originated from outside of Cosylab.
Hi Ralph, Abdalla,
I understand. Because there's no separate "installation
phase" it
doesn't seem possible to achieve what I was thinking.
Lucas
Hi Lucas,
Why not? Unless I misunderstood what you want, you could do
make
INSTALL_LOCATION=${HOME}/tmp/staging/ FINAL_LOCATION=/opt/test
sudo mv
${HOME}/tmp/staging/ /opt/test
sudo chown -R
epics:epics /opt/test #
Or root, or whatever
Perhaps having the staging directory under $(TOP) or /tmp makes
more sense, it depends on your case, but you get the idea. Would
this work for you?
Or, if you really want to use make, you can obviously use INSTALL_LOCATION for your staging area, FINAL_LOCATION for the target area and add something like
final-install:
mkdir -p $(FINAL_LOCATION); cp -a $(INSTALL_LOCATION)/* $(FINAL_LOCATION)
to the end of your top Makefile.
Cheers, ~Ralph
- How to use INSTALL_LOCATION with system directories Lucas Russo via Tech-talk
- Re: How to use INSTALL_LOCATION with system directories Ralph Lange via Tech-talk
- Re: How to use INSTALL_LOCATION with system directories Lucas Russo via Tech-talk
- Re: How to use INSTALL_LOCATION with system directories Jure Varlec via Tech-talk
- Re: How to use INSTALL_LOCATION with system directories Maren Purves via Tech-talk
<2023>
2025
RE: How to use INSTALL_LOCATION with system directories Abdalla Ahmad via Tech-talk
<2023>
2025
ANJ, 10 Oct 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
