1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Question regarding ADPluginFile driver
From: Jörn Dreyer via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, Mark Rivers <[email protected]>
Date: Wed, 11 Oct 2023 10:01:58 +0200
Hi Mark,
I just tested the code as is. If I set ’ Capture (numCapture) to 0 it works as expected. It captures data into the file indefinitely.
That's exactly what I wanted to have. I just remembered that I sat it to 0 in the HDF5 plugin and this one complained about this setting.
Jörn
Am Dienstag, 10. Oktober 2023, 19:17:17 CEST schrieb Mark Rivers:
> Hi Jörn,
> I am curious whether you might use NDPluginPva for sending the data via a stream over the network?  That is a common thing to do.
> NDPluginFile does not currently have a mechanism for continuous streaming.  A common workaround is to set NumCapture to a very large number, but that will eventually fail if the number of frames streamed is >2^31.
> From a quick look at the NDPluginFile code it seems that we could change the logic so that if NumCapture is 0 it will stream forever.  It would require changes in the following lines so that the comparison with numCapture is only done if it is non-zero.
> https://github.com/areaDetector/ADCore/blob/076bd4543827798537fa486c00e334722e9889f4/ADApp/pluginSrc/NDPluginFile.cpp#L743
> https://github.com/areaDetector/ADCore/blob/076bd4543827798537fa486c00e334722e9889f4/ADApp/pluginSrc/NDPluginFile.cpp#L750
> https://github.com/areaDetector/ADCore/blob/076bd4543827798537fa486c00e334722e9889f4/ADApp/pluginSrc/NDPluginFile.cpp#L767
> I think that would be backwards compatible because NumCapture=0 currently does not do anything useful.  If the user sets NumCapture=0 that might cause existing plugins to fail.  But there is nothing preventing users from doing that now, e.g. the NumCapture record does not set DRVL=1.
> If you want to test this and issue a Pull Request I'll be happy to look at it.
> Mark
> -----Original Message-----
> From: Tech-talk <[email protected]> On Behalf Of Jörn Dreyer via Tech-talk
> Sent: Tuesday, October 10, 2023 4:49 AM
> To: [email protected]
> Subject: Question regarding ADPluginFile driver
> Hi,
> I am currently developing an ADPluginFile driver that will  send the data via a stream over the network to a remote process for fast analysis. It can also store the data locally in various formats.
> For the network transfer I would like to be able to do continuous streaming without automatic limit by a defined number of events.
> Is that possible? Or can it be implemented within my code?
> Regards,
> Jörn
Dr. Jörn Dreyer
HIBEF DAQ + Controls
Institut für Strahlenpysik
Abt. FWKX
Tel: +49 351 260 3263
Fax: +49 351 260 123263
Helmholtz-Zentrum Dresden - Rossendorf e.V. (HZDR)
Bautzner Landstr. 400 | 01328 Dresden | Germany
Tel: +49 (0) 351 260 1234
http://www.hzdr.de
Vorstand: Prof. Dr. Sebastian M. Schmidt, Dr. Diana Stiller
Vereinsregister: VR 1693 beim Amtsgericht Dresden
RE: Question regarding ADPluginFile driver Mark Rivers via Tech-talk
Question regarding ADPluginFile driver Jörn Dreyer via Tech-talk
Prev: Re: Install EPICS on Raspberry pi and control motor Jörn Dreyer via Tech-talk
Next: creating soft channel ioc to interface with real ioc Tran, Phi Dung via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Question regarding ADPluginFile driver Jörn Dreyer via Tech-talk
Next: RE: Question regarding ADPluginFile driver Mark Rivers via Tech-talk
