1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: process multiple lines with streamdevice
From: Gerrit Kühn via Tech-talk <[email protected]>
To: Zimoch Dirk <[email protected]>
Date: Fri, 13 Oct 2023 15:10:02 +0200
Am Fri, 13 Oct 2023 12:53:43 +0000
schrieb Zimoch Dirk <[email protected]>:
Hello Dirk,
> If you do not set your InTerminator to the normal line terminator for
> this protocol (i.e. inside the { } ), then the 'in' command will read
> all the lines (terminated by readTimeout).
Great suggestion, I'll try that.
> If there is a "special"
> terminator after reply (e.g. 2 newlines) even better: Set InTerminator
> accordingly.
Unfortunately not, I will have to wait for the timeout. But that would be
ok, this is supposed to be done only once during IOC initilisation.
> in "%/unique identifier[^\n]*/";
> in "%.1/unique identifier/([\n]*)";
> in "%*/unique identifier/%f)";
> in "%*/unique identifier/%(\$1:rec1)f,%(\$1:rec1)f,%f";
I will have to parse tag=value stuff further down the road (see below), so
what I have come up with so far looks like this (searching for a given uid
and parsing for the identifier afterwards):
in "%.1/uid=\$1.*?device-identifier=([-a-z0-9]+)/";
> Give example data for more details (so that I do not have to guess).
The answers for a full bus look like this (Tinkerforge stuff via a text
proxy, extra newlines between the blocks added manually for posting):
uid=62C6Tx\tconnected-uid=0\tposition=0\thardware-version=3,1,0\tfirmware-version=2,5,2\tdevice-identifier=master-brick\tenumeration-type=available\n
uid=Tm6\tconnected-uid=62C6Tx\tposition=a\thardware-version=1,0,0\tfirmware-version=2,0,2\tdevice-identifier=industrial-digital-out-4-v2-bricklet\tenumeration-type=available\n
uid=YmR\tconnected-uid=62C6Tx\tposition=b\thardware-version=1,0,0\tfirmware-version=2,0,2\tdevice-identifier=isolator-bricklet\tenumeration-type=available\n
uid=XKM\tconnected-uid=62C6Tx\tposition=c\thardware-version=1,0,0\tfirmware-version=2,0,2\tdevice-identifier=industrial-digital-in-4-v2-bricklet\tenumeration-type=available\n
uid=Ymq\tconnected-uid=62C6Tx\tposition=d\thardware-version=1,0,0\tfirmware-version=2,0,2\tdevice-identifier=isolator-bricklet\tenumeration-type=available\n
uid=P7w\tconnected-uid=YmR\tposition=Z\thardware-version=1,0,0\tfirmware-version=2,0,1\tdevice-identifier=analog-out-v3-bricklet\tenumeration-type=available\n
uid=23Uu\tconnected-uid=Ymq\tposition=Z\thardware-version=1,0,0\tfirmware-version=2,0,7\tdevice-identifier=industrial-dual-analog-in-v2-bricklet\tenumeration-type=available\n
Thanks for the already very usefuls hints!
cu
  Gerrit
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: process multiple lines with streamdevice Zimoch Dirk via Tech-talk
process multiple lines with streamdevice Gerrit Kühn via Tech-talk
Prev: Re: process multiple lines with streamdevice Zimoch Dirk via Tech-talk
Next: Re: process multiple lines with streamdevice Zimoch Dirk via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
