Am Fri, 13 Oct 2023 13:29:17 +0000
schrieb Zimoch Dirk <[email protected]>:
> Two things to keep in mind:
> 1. Once %/regex/ has skipped something, there is no way back. Thus if
> you have multiple of those in one protocol, the order must stay fixed.
Yes, that will be the case. Right now, I just try to get this to work at
all, so I only try to match one of the pairs for starters. Once this works,
the others should hopefully be easy to add.
> 2. Any unread line after the one used will cause an error unless you set
> ExtraInput=ignore in this protocol. (Normally I discourage people to use
> that.)
Right now I do exactly that, just to make it easier to get things working.
Later it should be possible to match for the last setting (which should be
identical for all entries) just to finish in a tidy way.
cu
Gerrit
smime.p7s
Description: S/MIME cryptographic signature
- RE: [EXTERNAL] Re: process multiple lines with streamdevice Baily, Scott A via Tech-talk
- Re: process multiple lines with streamdevice Gerrit Kühn via Tech-talk
- process multiple lines with streamdevice Gerrit Kühn via Tech-talk
- Re: process multiple lines with streamdevice Zimoch Dirk via Tech-talk
Re: DBRecord <-> PVRecord data exchange Veseli, Sinisa via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
