Andrew, thanks for the answer!
None of the links provided in your email work for me.
It might be something with github?
Marco
Hi Marco,
The master index page at
https://areadetector.github.io/master/index.html is working for me; your link seems to have been lower-cased which probably won't work, try this one instead for the NDPluginDriver:
https://areadetector.github.io/master/ADCore/NDPluginDriver.html
- Andrew
Complexity comes for free, Simplicity you have to work for.
Good morning all, i have been trying to access the documentation in
https://areadetector.github.io/master/ since last week. Did something happen to it? Is there any other good source for the latest versions?
att,
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente
antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before
copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
- Re: Is areaDetector documentation down? Marco A. Barra Montevechi Filho via Tech-talk
- Re: Is areaDetector documentation down? Johnson, Andrew N. via Tech-talk
- Re: Is areaDetector documentation down? Pete Jemian via Tech-talk
- Is areaDetector documentation down? Marco A. Barra Montevechi Filho via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
