1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Is areaDetector documentation down?
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Marco A. Barra Montevechi Filho" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 23 Oct 2023 15:22:55 +0000
It sounds like this is a routing issue for you, your Ophyd link works for me (and my comment above about lower-casing your links was apparently another "feature" of MS Outlook that I'm forced to use now).
- Andrew
Complexity comes for free, Simplicity you have to work for.
From: Marco A. Barra Montevechi Filho <[email protected]>
Date: Monday, October 23, 2023 at 10:11 AM
To: Johnson, Andrew N. <[email protected]>, [email protected] <[email protected]>
Andrew, thanks for the answer!
None of the links provided in your email work for me.
I noticed i also cant access https://nsls-ii.github.io/ophyd/ or the pyepics documentation in github.io
It might be something with github?
Marco
Sent: 23 October 2023 11:44
To: Marco A. Barra Montevechi Filho <[email protected]>; [email protected] <[email protected]>
Hi Marco,
The master index page at https://areadetector.github.io/master/index.html is working for me; your link seems to have been lower-cased which probably won't work, try this one instead for the NDPluginDriver: https://areadetector.github.io/master/ADCore/NDPluginDriver.html
- Andrew
From: Tech-talk <[email protected]> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <[email protected]>
Date: Monday, October 23, 2023 at 7:01 AM
To: [email protected] <[email protected]>
Subject: Is areaDetector documentation down?
Good morning all, i have been trying to access the documentation in https://areadetector.github.io/master/ since last week. Did something happen to it? Is there any other good source for the latest versions?
att,
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Is areaDetector documentation down? Marco A. Barra Montevechi Filho via Tech-talk
Re: Is areaDetector documentation down? Johnson, Andrew N. via Tech-talk
Re: Is areaDetector documentation down? Marco A. Barra Montevechi Filho via Tech-talk
Prev: Re: Is areaDetector documentation down? Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Is areaDetector documentation down? Pete Jemian via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Is areaDetector documentation down? Maren Purves via Tech-talk
