1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: pvxs configuration problem
From: Jörn Dreyer via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Thu, 26 Oct 2023 13:02:22 +0200
Hello,
while converting an application from pva to pvxs I ran into a strange problem that I could not solve.
I added pvxs to an IOC and observed a strange error from pvxput telling that the requested PV is seen on two ports of the host running my IOC: at 5075 and something > 30000.
After some fighting with the startup script, I figured out that I still had pva (qsrv) in my IOC included. After removing it, the error disapeared, but still I get an error that I can not write the variable.
Error St13runtime_error: Unable to assign value from "0"
when using pvxput pv:name 0. It perfectly works with pvput! Realy strange. I have no clue whats going wrong.
Jörn
Re: pvxs configuration problem Michael Davidsaver via Tech-talk
Prev: RE: [EXTERNAL] Re: RTEMS5 EPICS board support Baily, Scott A via Tech-talk
Next: Display Builder Web Runtime HTML pages Hasan SANSAR via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: [EXTERNAL] RTEMS BSP for MVME8100 Heinz Junkes via Tech-talk
Next: Re: pvxs configuration problem Michael Davidsaver via Tech-talk
ANJ, 27 Oct 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
