1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: pvxs configuration problem
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Jörn Dreyer <[email protected]>
Cc: [email protected]
Date: Fri, 27 Oct 2023 08:53:33 -0700
On 10/26/23 04:02, Jörn Dreyer via Tech-talk wrote:
Hello,
while converting an application from pva to pvxs I ran into a strange problem that I could not solve.
I added pvxs to an IOC and observed a strange error from pvxput telling that the requested PV is seen on two ports of the host running my IOC: at 5075 and something > 30000.
After some fighting with the startup script, I figured out that I still had pva (qsrv) in my IOC included. After removing it, the error disapeared,
Were you only seeing the warning message, or were you seeing differences in behavior?
fyi. so far I have ensured that both QSRV versions can coexist with only this warning.
However, I am considering ending this after PVA links are added to QSRV2.
but still I get an error that I can not write the variable.
Error St13runtime_error: Unable to assign value from "0"
when using pvxput pv:name 0. It perfectly works with pvput! Realy strange. I have no clue whats going wrong.
pvxput is not yet a replacement for pvput.  I am  recommending that end users continue
with pvput for the time being.
When pvxput gets an equivalent level of "polish", I will add an build option to
install it also with the "pvput" name.
pvxs configuration problem Jörn Dreyer via Tech-talk
Prev: RE: Display Builder Web Runtime HTML pages CAOUEN Loïc via Tech-talk
Next: workQPanic-Kernel work queue overflow while attempting async communication and thereafter initializing tyGSOctalModule with vxWorks Mrinal Bera via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: pvxs configuration problem Jörn Dreyer via Tech-talk
Next: Display Builder Web Runtime HTML pages Hasan SANSAR via Tech-talk
