Hello,
I have a (probably very simple, but I fail to see the answer) question on
records with constant input:
What I'd like to have is a stringin record that is initialised with a
constant value that can later be changed with caput. From the
documentation on the stringin record I get
"The INP field determines where the string input record gets its string.
It can be a database or channel access link, or a constant. If constant,
the VAL field is initialized with the constant and can be changed via
dbPuts."
which sounds exactly like what I need.
However, when trying a record like
record (stringin, "$(P):$(T)-$(B)_$(R)_$(D)_$(UN)_UID")
{ field (DESC, "Device Identifier for $(U)")
field (DTYP, "Soft Channel")
field (INP, "test")
this does not work for me. I don't see any error messages, but I get an
empty record:
epics@epics-appl:~$ caget A0:PEM-3405_106_TF1_DO1_UID
What is even more strange (I think) is that I get an error message when
trying to write a value to this record:
epics@epics-appl:~$ caput A0:PEM-3405_106_TF1_DO1_UID
test
Old : A0:PEM-3405_106_TF1_DO1_UID
CA.Client.Exception...............................................
Warning: "Channel write request failed"
Context: "New : A0:PEM-3405_106_TF1_DO1_UID test
op=1, channel=A0:PEM-3405_106_TF1_DO1_UID, type=DBR_STRING, count=1,
ctx="A0:PEM-3405_106_TF1_DO1_UID"" Source File: ../oldChannelNotify.cpp
line 159 Current Time: Fri Nov 03 2023 11:04:49.636763495
The write appears to succeed anyway, though, the value is updated.
It looks like I can get the desired behaviour when using the VAL field
instead of INP in the record definition. While this is fine by me, it
feels like I misunderstand how the constant INP field is supposed to work
as described in the manual above. Could anyone shed a light on this mor me?
cu
Gerrit
smime.p7s
Description: S/MIME cryptographic signature
- Re: record with constant input link Simon Rose via Tech-talk
Re: Get the type of a PV in C++ API Eusebio Naif Al-Soliman Fuentes via Tech-talk
Re: process multiple lines with streamdevice Gerrit Kühn via Tech-talk
<2023>
2025
Re: AlliedVision Manta G-235B Miroslaw Dach via Tech-talk
<2023>
2025
