Hello Ralph.
First of all, thanks for your reply. I know the existence of PVXS library and I have already used it succesfully on my project. The problem is that, at the moment, I've noticed that it's slow for our project and I'm looking for a solution with the first-generation API.
It could also be an error in my code, what I'm doing at the moment is this:
pvxs::Value reply = ctxt.get(var_name_str).exec()->wait();
pvxs::TypeCode type_var = reply["value"].type();
Thanks, Eusebio.
Saludos/Best regards
University of Granada
Eusebio Naif Al-Soliman Fuentes MSc. Data Science and Computer Engineering
eunaif at correo.ugr.es
El 2023-11-02 15:01, Ralph Lange via Tech-talk escribió:
Not an answer to your question, but...
That library you are using is part of the first generation of user-facing libraries. Meanwhile, there's a second generation (both for C++ and Java) with more modern and language-specific API designs. Better usability, easier to work with, better performance. These second-generation libraries are stable; they will be replacing the older generation. For your use case: The C++ second-generation library is called PVXS - https://urldefense.com/v3/__https://mdavidsaver.github.io/pvxs/__;!!D9dNQwwGXtA!QvJCJFvFjdyKLmOVaaoqQ-_7p7M-QOxB1j1874UChwdwp4EIbx70WhtalgizLcJWAVZmwNrzC6XHFczTXw-W7sCO$
For any new development - please start there. It will save you from migrating your application at some point in the near future.
Cheers, ~Ralph
On Thu, 2 Nov 2023 at 12:46, Eusebio Naif Al-Soliman Fuentes via Tech-talk < tech-talk at aps.anl.gov> wrote:
Hello everybody.
I have a small question. In the pvaClient library for C++ ( https://urldefense.com/v3/__https://docs.epics-controls.org/projects/pvaclient-cpp/en/latest/__;!!D9dNQwwGXtA!QvJCJFvFjdyKLmOVaaoqQ-_7p7M-QOxB1j1874UChwdwp4EIbx70WhtalgizLcJWAVZmwNrzC6XHFczTX6fDGW9p$ ) there are many examples to get the value and other fields of a PV.
However, in order to get the value as a double, like in this example https://urldefense.com/v3/__https://github.com/epics-rip/exampleCPP/blob/master/exampleClient/src/examplePvaClientGet.cpp__;!!D9dNQwwGXtA!QvJCJFvFjdyKLmOVaaoqQ-_7p7M-QOxB1j1874UChwdwp4EIbx70WhtalgizLcJWAVZmwNrzC6XHFczTXz1KPekp$ , you have to previously know that the PV value is a double. Is there any method to get the type (int, long, double...) of the value field? Something like ->getType().
Thanks in advance. --
*University of Granada *
Eusebio Naif Al-Soliman Fuentes *MSc. Data Science and Computer Engineering*
- Re: Get the type of a PV in C++ API Veseli, Sinisa via Tech-talk
- Re: Get the type of a PV in C++ API Michael Davidsaver via Tech-talk
- Get the type of a PV in C++ API Eusebio Naif Al-Soliman Fuentes via Tech-talk
- Re: Get the type of a PV in C++ API Ralph Lange via Tech-talk
RE: External: Re: Linux distribution suggestion for EPICS Vincent van Beveren via Tech-talk
record with constant input link Gerrit Kühn via Tech-talk
<2023>
2025
<2023>
2025
ANJ, 03 Nov 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
