Sinisa
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
Argonne National Laboratory
(630)252-9182
Hello Ralph.
First of all, thanks for your reply. I know the existence of PVXS library and I have already used it succesfully on my project. The problem is that, at the moment, I've noticed that it's slow for our project and I'm looking for a solution
with the first-generation API.
It could also be an error in my code, what I'm doing at the moment is this:
pvxs::Value
reply
= ctxt.get(var_name_str).exec()->wait();
pvxs::TypeCode
type_var
= reply["value"].type();
Thanks, Eusebio.
Saludos/Best regards
University of Granada
Eusebio Naif Al-Soliman Fuentes
MSc.
Data Science and Computer Engineering
[email protected]
El 2023-11-02 15:01, Ralph Lange via Tech-talk escribió:
Not an answer to your question, but...
That library you are using is part of the first generation of user-facing
libraries.
Meanwhile, there's a second generation (both for C++ and Java) with more
modern and language-specific API designs. Better usability, easier to work
with, better performance.
These second-generation libraries are stable; they will be replacing the
older generation.
For your use case: The C++ second-generation library is called PVXS -
https://urldefense.com/v3/__https://mdavidsaver.github.io/pvxs/__;!!D9dNQwwGXtA!QvJCJFvFjdyKLmOVaaoqQ-_7p7M-QOxB1j1874UChwdwp4EIbx70WhtalgizLcJWAVZmwNrzC6XHFczTXw-W7sCO$
For any new development - please start there. It will save you from
migrating your application at some point in the near future.
Cheers,
~Ralph
On Thu, 2 Nov 2023 at 12:46, Eusebio Naif Al-Soliman Fuentes via Tech-talk <
[email protected]> wrote:
Hello everybody.
I have a small question. In the pvaClient library for C++ (
https://urldefense.com/v3/__https://docs.epics-controls.org/projects/pvaclient-cpp/en/latest/__;!!D9dNQwwGXtA!QvJCJFvFjdyKLmOVaaoqQ-_7p7M-QOxB1j1874UChwdwp4EIbx70WhtalgizLcJWAVZmwNrzC6XHFczTX6fDGW9p$
) there
are many examples to get the value and other fields of a PV.
However, in order to get the value as a double, like in this example
https://urldefense.com/v3/__https://github.com/epics-rip/exampleCPP/blob/master/exampleClient/src/examplePvaClientGet.cpp__;!!D9dNQwwGXtA!QvJCJFvFjdyKLmOVaaoqQ-_7p7M-QOxB1j1874UChwdwp4EIbx70WhtalgizLcJWAVZmwNrzC6XHFczTXz1KPekp$
you have to previously know that the PV value is a double. Is there any
method to get the type (int, long, double...) of the value field? Something
like ->getType().
Thanks in advance.
*University of Granada *
*MSc. Data Science and Computer Engineering*
[email protected]
- Get the type of a PV in C++ API Eusebio Naif Al-Soliman Fuentes via Tech-talk
- Re: Get the type of a PV in C++ API Ralph Lange via Tech-talk
- Re: Get the type of a PV in C++ API Eusebio Naif Al-Soliman Fuentes via Tech-talk
Re: Sequencer interpretation of PV names with {,} characters Kasemir, Kay via Tech-talk
Re: record with constant input link Rolf Keitel via Tech-talk
<2023>
2025
2026
Re: Get the type of a PV in C++ API Michael Davidsaver via Tech-talk
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
