1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: record with constant input link
From: Rolf Keitel via Tech-talk <[email protected]>
To: [email protected]
Date: Fri, 3 Nov 2023 08:50:33 -0700
Title: signature text
Gerrit,
One should not initialize the VAL field of a stringin record by setting the INP field to a string
(or the VAL field of a stringout record by setting DOL), as the field value might be interpreted as
a record name and the link as a channel access link.
Keep in mind that on records where INP expects a number, a constant value is used to initialize VAL, but
a constant INP link is only processed at record initialization. Writing a new value to INP via channel access
or dbput will not update the VAL field.
On 2023-11-03 8:37 a.m., Gerrit Kühn via Tech-talk wrote:
Another issue I have been running into with this is the order of record
initialisation. The string in this record is needed by other records and
thus should be initialised first. But from what I have read on the web so
far I understand there is no mechanism to guarantee that within one
database. However, I probably could put records like this in a separate
database and load that one in st.cmd first?
For this (within one IOC) you can use the PHAS field of a record. Records with smaller PHAS values are processed before records with higher values.
Rolf Keitel, Ph.D.
Researcher Emeritus
e-mail: [email protected]
------ Home ------
4158 West 13th Ave
Vancouver, BC, V6R 2T6
604 228 0594
------ Office: ------
604 222 7453
TRIUMF Canada’s particle accelerator centre
4004 Wesbrook Mall Vancouver, BC, V6T 2A3
www.triumf.ca | Twitter | Facebook | Instagram
TRIUMF is located on the traditional, ancestral, and unceded territory of the xʷməθkʷəy̓əm (Musqueam) people,
who for millennia have passed on their culture, history, and traditions from one generation to the next on this site.
Re: record with constant input link Gerrit Kühn via Tech-talk
Re: record with constant input link Simon Rose via Tech-talk
Prev: Re: Get the type of a PV in C++ API Veseli, Sinisa via Tech-talk
Next: Re: Get the type of a PV in C++ API Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: record with constant input link Gerrit Kühn via Tech-talk
Next: Re: record with constant input link Gerrit Kühn via Tech-talk
