Am Fri, 3 Nov 2023 12:37:35 +0000
schrieb Simon Rose <[email protected]>:
> The INP link is meant to be the record that the stringin record fetches
> data from, which it would then write into the VAL field. You can see
> this by creating a second (e.g. stringout) record with the name "test",
> and then processing your stringin record at which point it will fetch
> the value from the stringout record.
Ah, great, there was my misconception, thanks!. Although I still don't
quite understand what a "constant" in "a database or channel access link,
or a constant" would mean in that context then. In your scenario above this
would not be a constant, right? Somehow this still feels like it does not
work as advertised in the manual.
> That said, if this is meant to be a constant string used by other
> resources, it would likely be better-suited as a stringout record;
> stringin records are for reading input from another source.
Yes, I was already thinking about that, too (but it looked like I had some
other misunderstanding that I wanted to sort out first ;-).
The string would be constant under most circumstances, but it should be
possible to change it via caput in certain (rare) cases.
Another issue I have been running into with this is the order of record
initialisation. The string in this record is needed by other records and
thus should be initialised first. But from what I have read on the web so
far I understand there is no mechanism to guarantee that within one
database. However, I probably could put records like this in a separate
database and load that one in st.cmd first?
cu
Gerrit
smime.p7s
Description: S/MIME cryptographic signature
- Re: record with constant input link Rolf Keitel via Tech-talk
- record with constant input link Gerrit Kühn via Tech-talk
- Re: record with constant input link Simon Rose via Tech-talk
Sequencer interpretation of PV names with {,} characters Ivashkevych, Oksana via Tech-talk
Re: Sequencer interpretation of PV names with {,} characters Kasemir, Kay via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
