1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Sequencer interpretation of PV names with {,} characters
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "Ivashkevych, Oksana" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 3 Nov 2023 15:38:27 +0000
SNL uses {macro} for macros, like the shell or database would use $(macro).
Not sure if there’s a way to escape curly brackets like “\{not_a_macro\}” …
From: Tech-talk <[email protected]> on behalf of Ivashkevych, Oksana via Tech-talk <[email protected]>
Date: Friday, November 3, 2023 at 11:30 AM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] Sequencer interpretation of PV names with {,} characters
Hello,
The PV names I would like to link to have {, } inside their names, e.g “XF:BM-ES{Psh_blade1}Pos”.
It appears that the sequencer module does not like the curly brackets.
The PV name inside my runTest.st file compiles well, but when I run the sequencer, the PV in question does not connect, with errors:
sevr=minor runTest[0](after 0 sec): assigned=1, connected=0, monitored=1, got monitor=0
Everything works if a PV does not have  {} in its name.
I was wondering if someone could comment on it, where it could be happening, and if it is possible to patch may be.
Thank you
Oksana
Re: Sequencer interpretation of PV names with {,} characters Kasemir, Kay via Tech-talk
Sequencer interpretation of PV names with {,} characters Ivashkevych, Oksana via Tech-talk
Prev: Re: record with constant input link Gerrit Kühn via Tech-talk
Next: Re: Sequencer interpretation of PV names with {,} characters Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Sequencer interpretation of PV names with {,} characters Ivashkevych, Oksana via Tech-talk
