1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: record with constant input link
From: Gerrit Kühn via Tech-talk <[email protected]>
To: Rolf Keitel via Tech-talk <[email protected]>
Date: Fri, 3 Nov 2023 17:05:38 +0100
Am Fri, 3 Nov 2023 08:50:33 -0700
schrieb Rolf Keitel via Tech-talk <[email protected]>:
> One should not initialize the VAL field of a stringin record by setting
> the INP field to a string
> (or the VAL field of a stringout record by setting DOL), as the field
> value might be interpreted as
> a record name and the link as a channel access link.
I see. But why is this written in the manual for stringin records then?
The INP field determines where the string input record gets its string. It
can be a database or channel access link, or a constant. If constant, the
VAL field is initialized with the constant and can be changed via dbPuts.
This is not what I see when setting the INP field to a constant string
value. Or does "constant" mean something different in this context?
> Keep in mind that on records where INP expects a number, a constant
> value is used to initialize VAL, but
> a constant INP link is only processed at record initialization. Writing
> a new value to INP via channel access
> or dbput will not update the VAL field.
This is also quite the opposite of what I get from the manual?!
> > Another issue I have been running into with this is the order of record
> > initialisation.
> For this (within one IOC) you can use the PHAS field of a record.
> Records with smaller PHAS values are processed before records with
> higher values.
Great, thanks for the pointer. I hadn't seen that one before.
cu
  Gerrit
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: record with constant input link Ralph Lange via Tech-talk
Re: record with constant input link Johnson, Andrew N. via Tech-talk
Re: record with constant input link Gerrit Kühn via Tech-talk
Re: record with constant input link Simon Rose via Tech-talk
Re: record with constant input link Rolf Keitel via Tech-talk
Prev: Re: Get the type of a PV in C++ API Michael Davidsaver via Tech-talk
Next: ADPerkinElmer Bad Pixel Files Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: record with constant input link Rolf Keitel via Tech-talk
Next: Re: record with constant input link Ralph Lange via Tech-talk
