1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: AlliedVision Manta G-235B
To: Miroslaw Dach <[email protected]>, "Cobb, Tom (DLSLtd,RAL,LSCI)" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 6 Nov 2023 20:51:30 +0000
ADVimba works on Windows and supports interfaces besides just USB and GigE.  For GigE on Linux either works fine.
Sent: Monday, November 6, 2023 2:06 PM
To: Cobb, Tom (DLSLtd,RAL,LSCI) <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>; Mark Rivers <[email protected]>
Subject: Re: AlliedVision Manta G-235B
Hi Mark and Tom,
Many thanks for sharing your expertise and experience with the camera.
Currently we use ADProsilica driver for Manta G-145B which looks obsolete and is not supported any more.
Which one is better to use for Manta cameras instead: ADVimba or ADAravis ?
Thanks.
Best Regards
Mirek
On Mon, Nov 6, 2023 at 4:24 AM Cobb, Tom (DLSLtd,RAL,LSCI) <[email protected]> wrote:
Hi Mirek,
We use the Manta G-235B with ADAravis and it works well. As Mark says, the sensor is much better than the earlier CCD sensors.
Tom
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Sent: 04 November 2023 13:27
To: EPICS Tech-Talk <[email protected]>; Miroslaw Dach <[email protected]>
Hi Mirek,
The Manta G-145B uses the Sony ICX-285 CCD sensor.  It is 1388x1038 pixels and does 15 frames/s.
The Manta G-235B uses the Sony IMX-174 CMOS sensor.   It is 1936x1215 pixels and does 50 frames/s.  It is a much better sensor than the ICX-285 with more pixels, greater full well capacity, better sensitivity and higher speed.
I don't have experience with that camera, but I do have experience with that sensor in cameras from FLIR (formerly Point Grey).  I have extensively used these models:
GS3-U3-23S6M-C  This is a USB-3 version that does 163 frames/s 8-bit and 110 frames/s 12-bit.
GS3-PGE-23S6M-C  This is a GigE version that does 48 frames/s 8-bit and 29 frames/s 12-bit.
Any of these cameras should work fine.
If you go with the Allied Vision camera I recommend you switch from the ADProsilica driver to the ADVimba or ADAravis drivers.  ADProsilica is based on a very old SDK that is no longer supported.
From: Tech-talk <[email protected]> on behalf of Miroslaw Dach via Tech-talk <[email protected]>
Sent: Friday, November 3, 2023 1:49 AM
Subject: AlliedVision Manta G-235B
Hi folks,
We have been using in ALS the AlliedVision Manta G-145B cameras with areaDetector ADProsilica driver for several years .
The G-145B cameras are used to capture beam spot images in ALS.
This camera model is not produced any more so we are searching for an alternative.
The AlliedVision suggested an alternative model: Manta G-235B with similar specification.
Do any of you have experience with  Manta G-235B cameras or other models which could be worth considering?
Our requirements are:
GigE standard
pixel size under: 10um x 10um
sensor size 2/3"
update rate 10Hz
12 bits  CCD/CMOS
image size like:  1390x1038
triggerable with the external trigger
preferred:
24V power
C-Mount
Best Regards
Mirek
Re: AlliedVision Manta G-235B Miroslaw Dach via Tech-talk
Re: AlliedVision Manta G-235B Mark Rivers via Tech-talk
Re: AlliedVision Manta G-235B Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Prev: Re: AlliedVision Manta G-235B Miroslaw Dach via Tech-talk
Next: Re: AlliedVision Manta G-235B Miroslaw Dach via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
