1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: labjack support, command not found
From: "Wolfman, Mark via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 7 Nov 2023 18:17:54 +0000
Hi, Mark.
Got it, thank you.
Cheers,
My work schedule may not be the same as your work schedule. Please
don't feel obligated to respond to this e-mail outside of your
normal work hours.
Sent: Tuesday, November 7, 2023 11:00
To: Wolfman, Mark; [email protected]
Subject: RE: labjack support, command not found
Hi Mark,
You should remove that line.  That line is in the example st.cmd files in Labjack because they are initializing the IOC.  But when you put Labjack support in another IOC your st.cmd will already have called xxxAppRegisterRecordDeviceDriver for your application.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Wolfman, Mark via Tech-talk
Sent: Tuesday, November 7, 2023 10:07 AM
To: [email protected]
Subject: labjack support, command not found
Hi, all.
I'm using the epics labjack module v3.0.0 and trying to include it in an existing IOC. I downloaded it from git (commit 61e3c59d91a721ccef8f5504cb1ba4cab5e0cba8) and modified it to build from APSshare since I don't have a corvette. The separate IOC builds fine and the labjack seems to work, but there is this error message in the IOC console:
> LabJack.cmd line 13: Command LabJackApp_registerRecordDeviceDriver not found.
which references the line ``LabJackApp_registerRecordDeviceDriver(pdbbase)``
I'm not clear on what this command does. Can I fix this error somehow, or else can I safely remove that offending line since the IOC seems to work as expected?
Here's the lines that I added to st.cmd: https://gist.github.com/canismarko/e4bc0c61fcf7c5b4803d69a7a691cb30
based on: https://github.com/epics-modules/LabJack/blob/master/iocBoot/iocLabJack_T7/st.cmd
My work schedule may not be the same as your work schedule. Please don't feel obligated to respond to this e-mail outside of your normal work hours.
labjack support, command not found Wolfman, Mark via Tech-talk
RE: labjack support, command not found Mark Rivers via Tech-talk
Prev: RE: labjack support, command not found Mark Rivers via Tech-talk
Next: second relative motion stuck in a do loop Tran, Phi Dung via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
