1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: CS-Studio XY Graph problem with >2046 samples
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "Heesterman, Peter" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 8 Nov 2023 15:07:09 +0000
You may run into the default setting for the EPICS_CA_MAX_ARRAY size of ~16k.
With “double” waveforms, 2046 samples * 8 bytes = 16k.
For phoebus the settings are described in https://control-system-studio.readthedocs.io/en/latest/preference_properties.html#pv-ca.
We set the default to  100000000, so that supports 2046 double samples.
For the Eclipse-based CSS, the way it’s configured has changed over time, you’ll have to see what applies to your version, to increase it from the default 16k.
-Kay
From: Tech-talk <[email protected]> on behalf of Heesterman, Peter via Tech-talk <[email protected]>
Date: Wednesday, November 8, 2023 at 9:51 AM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] CS-Studio XY Graph problem with >2046 samples
I’m using (Eclipse-based) CS-Studio 4.5.9 on Windows, and 4.8.1 within the ITER CS Red Hat installation.
I’m experiencing the same problem for both – when the number of samples in the waveform trace exceeds 2046, the OPI becomes very erratic and fails to display any further data.
Also, the IOC typically fails at the same time.
When this happens, CS-Studio repeatedly shows the error:
2023-11-08 14:01:51 ERROR: Error from pv connection layer:
java.lang.IllegalStateException: transport closed
If CS-Studio is not displaying the OPI, the IOC behaves perfectly for any number of samples.
I’ve also tested the behaviour when using Phoebus, instead of CS-Studio - both the OPI and the IOC then work perfectly.
Does anyone have suggestions as to how this problem might be resolved?
Many thanks,
Peter.
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
RE: CS-Studio XY Graph problem with >2046 samples Heesterman, Peter via Tech-talk
Prev: CS-Studio XY Graph problem with >2046 samples Heesterman, Peter via Tech-talk
Next: Re: CS-Studio XY Graph problem with >2046 samples Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: RE: CS-Studio XY Graph problem with >2046 samples Heesterman, Peter via Tech-talk
