1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: [EXTERNAL] CS-Studio XY Graph problem with >2046 samples
From: "Heesterman, Peter via Tech-talk" <[email protected]>
To: "Hartman, Steven" <[email protected]>
Date: Wed, 8 Nov 2023 16:43:19 +0000
Hi Steven,
The IOC sometimes fails by just exiting without a message.
Often though, there are messages like this:
epics> CAS: request from 192.168.1.181:64542 => bad resource ID
CAS: Request from 192.168.1.181:64542 => cmmd=2 cid=0x108 type=14 count=1 postsize=0
CAS: Request from 192.168.1.181:64542 =>   available=0x14f       N=0 paddr=0000025523291798
CAS: forcing disconnect from 192.168.1.181:64542
CAS: request from 192.168.1.181:64566 => bad resource ID
CAS: Request from 192.168.1.181:64566 => cmmd=2 cid=0xd05 type=14 count=1 postsize=0
CAS: Request from 192.168.1.181:64566 =>   available=0x1610   N=0 paddr=0000025523292398
CAS: forcing disconnect from 192.168.1.181:64566
CAS: request from 192.168.56.1:64668 => bad resource ID
CAS: Request from 192.168.56.1:64668 => cmmd=1 cid=0xd23 type=20 count=0 postsize=16
CAS: Request from 192.168.56.1:64668 =>   available=0x1641      N=0 paddr=0000000000000000
CAS: forcing disconnect from 192.168.56.1:64668
CAS: forcing disconnect from 127.0.0.1:64671
CAS: request from 192.168.1.181:65213 => bad resource ID
CAS: Request from 192.168.1.181:65213 => cmmd=2 cid=0x42e9 type=17 count=1 postsize=0
CAS: Request from 192.168.1.181:65213 =>   available=0x74fa    N=0 paddr=0000025523290538
CAS: forcing disconnect from 192.168.1.181:65213
CAS: request from 192.168.1.181:50113 => bad resource ID
CAS: Request from 192.168.1.181:50113 => cmmd=2 cid=0xa6fd type=20 count=1 postsize=0
CAS: Request from 192.168.1.181:50113 =>   available=0x1249d                 N=0 paddr=0000025523290238
CAS: forcing disconnect from 192.168.1.181:50113
CAS: forcing disconnect from 127.0.0.1:50178
Cheers,
Peter.
Sent: 08 November 2023 15:47
To: Heesterman, Peter <[email protected]>
Cc: [email protected]
Subject: Re: [EXTERNAL] CS-Studio XY Graph problem with >2046 samples
This mail has been sent from an external source. Do not reply to it, or open any links/attachments unless you are sure of the sender's identity.
On Nov 8, 2023, at 9:36 AM, Heesterman, Peter via Tech-talk <[email protected]> wrote:
Also, the IOC typically fails at the same time.
What do you mean by the IOC “fails”? Any error messages on the console when this happens?
Steven Hartman
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
CS-Studio XY Graph problem with >2046 samples Heesterman, Peter via Tech-talk
Re: [EXTERNAL] CS-Studio XY Graph problem with >2046 samples Hartman, Steven via Tech-talk
Prev: RE: CS-Studio XY Graph problem with >2046 samples Heesterman, Peter via Tech-talk
Next: Re: caget -d DBR_...INT doesn't work Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: [EXTERNAL] CS-Studio XY Graph problem with >2046 samples Hartman, Steven via Tech-talk
Next: Room temperature and humidity monitoring with EPICS? Jesse Hopkins via Tech-talk
