1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Room temperature and humidity monitoring with EPICS?
From: Jesse Hopkins via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 10 Nov 2023 11:46:44 -0600
Hi folks,
We're looking for a way to monitor humidity and temperature in our experimental enclosures (beamline hutches), with readings that we can access via EPICS. I'd prefer something ethernet based, and low cost is always good. I strongly suspect folks in the EPICS community have already done this in a variety of ways, though I wasn't able to turn anything obvious up in a search.
Does anyone have a good solution that you're using?
I suspect that if there's nothing else out there I could just buy some analog input boxes (e.g. LabJack or Measurement Computing) and hook up a couple of sensors, but I'm hoping there's a better/cheaper solution.
All the best.
- Jesse
Jesse Hopkins, PhD
Deputy Director
BioCAT, Sector 18
Advanced Photon Source
Re: Room temperature and humidity monitoring with EPICS? Pierrick M Hanlet via Tech-talk
Re: Room temperature and humidity monitoring with EPICS? Han Lee via Tech-talk
Re: Room temperature and humidity monitoring with EPICS? Matt Newville via Tech-talk
Re: Room temperature and humidity monitoring with EPICS? Gerrit Kühn via Tech-talk
Re: Room temperature and humidity monitoring with EPICS? J. Lewis Muir via Tech-talk
Prev: Re: second relative motion stuck in a do loop Kevin Peterson via Tech-talk
Next: Re: Room temperature and humidity monitoring with EPICS? Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: RE: [EXTERNAL] CS-Studio XY Graph problem with >2046 samples Heesterman, Peter via Tech-talk
