1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Room temperature and humidity monitoring with EPICS?
From: Gerrit Kühn via Tech-talk <[email protected]>
To: Jesse Hopkins via Tech-talk <[email protected]>
Date: Mon, 13 Nov 2023 08:24:17 +0100
Am Fri, 10 Nov 2023 11:46:44 -0600
schrieb Jesse Hopkins via Tech-talk <[email protected]>:
Hello,
We are working on EPICS integration of some Tinkerforge devices
(https://www.tinkerforge.com/en/) that we intend to use for pem monitoring
in our labs. There is a large range of so-called bricklets available, a
couple of them supporting humidity and temperature measurements. A direct
ethernet connection is available (PoE if you want), communication is
possible via StreamDevice. The whole project is very open (both in
software and in hardware).
HTH
cu
  Gerrit
> Hi folks,
> We're looking for a way to monitor humidity and temperature in our
> experimental enclosures (beamline hutches), with readings that we can
> access via EPICS. I'd prefer something ethernet based, and low cost is
> always good. I strongly suspect folks in the EPICS community have already
> done this in a variety of ways, though I wasn't able to turn anything
> obvious up in a search.
> Does anyone have a good solution that you're using?
> I suspect that if there's nothing else out there I could just buy some
> analog input boxes (e.g. LabJack or Measurement Computing) and hook up a
> couple of sensors, but I'm hoping there's a better/cheaper solution.
> All the best.
> - Jesse
> Jesse Hopkins, PhD
> Deputy Director
> BioCAT, Sector 18
> Advanced Photon Source
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Room temperature and humidity monitoring with EPICS? Jesse Hopkins via Tech-talk
Prev: Re: [Ext] Re: Room temperature and humidity monitoring with EPICS? Jesse Hopkins via Tech-talk
Next: Re: [Ext] Re: Room temperature and humidity monitoring with EPICS? Matt Newville via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: Room temperature and humidity monitoring with EPICS? J. Lewis Muir via Tech-talk
