1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Room temperature and humidity monitoring with EPICS?
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: Jesse Hopkins <[email protected]>
Date: Mon, 13 Nov 2023 14:46:14 -0600
On 11/10, Jesse Hopkins via Tech-talk wrote:
> We're looking for a way to monitor humidity and temperature in our
> experimental enclosures (beamline hutches), with readings that we can
> access via EPICS. I'd prefer something ethernet based, and low cost is
> always good. I strongly suspect folks in the EPICS community have already
> done this in a variety of ways, though I wasn't able to turn anything
> obvious up in a search.
> Does anyone have a good solution that you're using?
Hi, Jesse!
We use the Esensors Websensor EM01B:
  https://eesensors.com/products/websensors/server-room-temperature-monitoring.html
There's an EPICS driver at
  https://imca-cat.org/~jlmuir/sw/websensor-em01b.html
Lewis
Room temperature and humidity monitoring with EPICS? Jesse Hopkins via Tech-talk
Prev: Re: [Ext] Re: Room temperature and humidity monitoring with EPICS? Jesse Hopkins via Tech-talk
Next: Re: second relative motion stuck in a do loop Tran, Phi Dung via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Room temperature and humidity monitoring with EPICS? Gerrit Kühn via Tech-talk
Next: Re: Sequencer website broken Ben Franksen via Tech-talk
