1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: second relative motion stuck in a do loop
From: Kevin Peterson via Tech-talk <[email protected]>
To: "Tran, Phi Dung" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 9 Nov 2023 10:04:52 -0600
Phi,
Are any of the motors (real or soft) doing retries?
How does the $(P)-DMOV record's behavior differ between the 1st relative move, which succeeds, and the 2nd relative move, which misbehaves?
Kevin
On 11/7/23 22:23, Tran, Phi Dung via Tech-talk wrote:
I am using RLV for relative motion with a soft channel. When I issue a caput command with a value of 2 to my soft channel, $(P), to move the other real motors, they move by 2 mm. However, when I repeat the caput command with the value 2 to my soft channel for the second time, the motors move by 7*2=14 mm instead of 2 mm. Please advise.
Thank you,
Phi
Re: second relative motion stuck in a do loop Tran, Phi Dung via Tech-talk
Prev: Re: ADPerkinElmer Bad Pixel Files Mark Rivers via Tech-talk
Next: AW: ADPerkinElmer Bad Pixel Files Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: second relative motion stuck in a do loop Tran, Phi Dung via Tech-talk
Next: Re: second relative motion stuck in a do loop Tran, Phi Dung via Tech-talk
