1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Alarms.services in Phoebus Alarms
Date: Thu, 16 Nov 2023 15:23:03 +0800 (GMT+08:00)
I'm having a problem with alarm-servers. I've attached the error. Phoebus shows normal when I execute the ./alarm-server.sh directly in the terminal, but it shows ‘No Alarm Server Connection’ when I use the alarms.service file for autostart. At the same time, I find it strange that the alarm config file can be imported successfully. It seems that the alarm-server can connect to Phoebus, but PV cannot. The PV data is incorrect, and what is the reason for this?
The alarms.server file is as follows:
[Unit]
After=network.target kafka.target
Requires=zookeeper.service
Requires=kafka.service
[Service]
User=sysadmin
Type=simple
ExecStart=/opt/alarm/phoebus/services/alarm-server/alarm-service.sh -settings /opt/alarm/phoebus/services/alarm-server/settings.ini
WorkingDirectory=/opt/alarm/phoebus/services/alarm-server/
RemainAfterExit=true
[Install]
WantedBy=multi-user.target
xiaomin
Attachment: 2.png
Description: PNG image
RE: Alarms.services in Phoebus Alarms SAINTIN Katy via Tech-talk
Prev: RE: EPICS Archiver Appliance and Channel Filters Quemuel, Jonathan Kelii Kenji via Tech-talk
Next: Re: StreamDevice (streamCore::readCallback called unexpectedly) Zimoch Dirk via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: RE: RE: EPICS Archiver Appliance and Channel Filters Quemuel, Jonathan Kelii Kenji via Tech-talk
Next: RE: Alarms.services in Phoebus Alarms SAINTIN Katy via Tech-talk
