1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: StreamDevice (streamCore::readCallback called unexpectedly)
From: Zimoch Dirk via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 16 Nov 2023 08:04:44 +0000
Hi Andrew,
That is interesting. I have never seen this behavior and would like to reproduce
it. But for that, I need to understand exactly what happens.
StreamDevice claiming something "unexpected" happens of course means that I
never expected it to happen and thus I have no idea how to force this behavior.
Thus, the more precisely you can tell me what exactly your instrument does, the
higher the chance I can fix it.
Does the instrument shutdown its socket? Or does it simply switch off its
network interface? Or is it for example a firewall that interrupts the
connection? Can you get the same behavior switching off your instrument or
pulling the network cable? Anything I can try without having access to your
instruments?
Dirk
On Wed, 2023-11-15 at 19:24 +0000, Wang, Andrew via Tech-talk wrote:
> Hi all,
> This is kind of a general question, but we have an IOC that is running 24 instruments, all of the same type. We have them set to DHCP and a timeout of 30s meaning that the connection closes if the instrument does not receive TCP/IP commands after 30s.
> I have a fanout that processes records and fetches values from the instruments through queries defined in a protocol file. After 30s, the IOC would output a plethora of error messages from StreamDevice that all say streamCore::readCallback(rec_name) called unexpectedly. It doesn’t do that every 1 second, which is what I have the scan rate of the fanout record set to.
> It would be great if somebody could shed some light on scenarios that could cause this error message to be generated.
> Thank you,
> Andy
> Purple ribbon awareness
StreamDevice (streamCore::readCallback called unexpectedly) Wang, Andrew via Tech-talk
Prev: Alarms.services in Phoebus Alarms 刘晓敏 via Tech-talk
Next: RE: Alarms.services in Phoebus Alarms SAINTIN Katy via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: RE: StreamDevice (streamCore::readCallback called unexpectedly) Mark Rivers via Tech-talk
Next: Highland P500 support? Jeff Kirchman via Tech-talk
