1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: StreamDevice (streamCore::readCallback called unexpectedly)
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Wed, 15 Nov 2023 19:24:08 +0000
Hi all,
This is kind of a general question, but we have an IOC that is running 24 instruments, all of the same type. We have them set to DHCP and a timeout of 30s meaning that the connection closes if the instrument does not receive TCP/IP commands after 30s.
I have a fanout that processes records and fetches values from the instruments through queries defined in a protocol file. After 30s, the IOC would output a plethora of error messages from StreamDevice that all say streamCore::readCallback(rec_name) called unexpectedly. It doesn’t do that every 1 second, which is what I have the scan rate of the fanout record set to.
It would be great if somebody could shed some light on scenarios that could cause this error message to be generated.
Thank you,
Andy
Purple ribbon awareness
RE: StreamDevice (streamCore::readCallback called unexpectedly) Mark Rivers via Tech-talk
Re: StreamDevice (streamCore::readCallback called unexpectedly) Zimoch Dirk via Tech-talk
Prev: AW: ADPerkinElmer Bad Pixel Files Sintschuk, Michael via Tech-talk
Next: RE: StreamDevice (streamCore::readCallback called unexpectedly) Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Sequencer website broken Ralph Lange via Tech-talk
