1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: synApps build
To: "Lang, Keenan C." <[email protected]>
Date: Fri, 17 Nov 2023 18:32:54 +0000
Pete,
If you want to use PVA with 3.15.9 you can do so. Look at areaDetector/configure/EXAMPLE_RELEASE_LIBS.local and EXAMPLE_RELEASE_PRODS.local.
Sent from my iPhone
On Nov 17, 2023, at 10:49 AM, Lang, Keenan C. via Tech-talk <[email protected]> wrote:
There is a configuration option in AreaDetector within the file AreaDetector/configure/CONFIG_SITE.local,
You can set WITH_PVA=NO in order to build without including the process variable access features introduced in Epics v4
Keenan
From: Tech-talk <[email protected]> on behalf of Siddons, David via Tech-talk <[email protected]>
Sent: Friday, November 17, 2023 10:30 AM
To: [email protected] <[email protected]>
Subject: synApps build
I'm trying to build synApps on a new PC. I want to use base-3.15.9, but the build fails with:
../ntndArrayConverter.h:5:10: fatal error: pv/ntndarray.h: No such file or directory
    5 | #include <pv/ntndarray.h>
Indeed, I don't see any reference to that file in 3.15.9, only in 7. Does that mean I can't build it on the older distribution? The failure comes from AreaDetector (3-11). The OS is Pop 22.04, which I believe is an Debian/Ubuntu variant.
Pete.
synApps build Siddons, David via Tech-talk
Re: synApps build Lang, Keenan C. via Tech-talk
Prev: Re: synApps build Siddons, David via Tech-talk
Next: caput works only the first time Tran, Phi Dung via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
